Have you tried the scripting function hs.shutdown?
Restarting Homeseer
Originally posted by Uncle Michael View PostHave you tried the scripting function hs.shutdown?
EDIT:
Ahhh... Search is a wonderful thing! I think that I found an old post on how to do this. Thanks for pointing me in the right direction.Last edited by automateme; August 6, 2008, 11:08 AM.
Your wish is my command
Just place Jon00ShutdownHS.exe in your Homeseer 2 directory and run it however you wish. I have not tested it as a command line but it should work.
Like the restart application, it will keep trying to gracefully shutdown Homeseer for 2 minutes. If that fails, Homesser is killed.Attached Files
Originally posted by sponnath View PostI have now reset it 3 times successfully. Trying to figure out what messes it up.
As I was playing around writing the shutdown version, I also reloaded the restart version and made a change which increase some of the timings. Give it a try and see if it makes any difference to your issues.Attached Files
sponnath
I noticed that my existing 75G Raptor drive in my Abit AB9 Pro was getting a lot of errors. I'm not sure that one of the Sata headers liked that Raptor. I got a new Raptor, let the old one offline as emergency backup and installed the new one on a different Sata header. I no longer get the drive read/write errors. I wanted to eliminate any possibilities of system problems before continuing on this 'quest'.
sponnath
Nope, just tried it. Same error.
Sure wished this worked. Getting tired of restarted HS every morning.
Anything else I can check? Are you looking for something in particular to find HS? I start it from the start up folder using a delay exe.
************** Exception Text **************
System.ComponentModel.Win32Exception: The system cannot find the file specified
at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessSt artInfo startInfo)
at System.Diagnostics.Process.Start()
at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start(String fileName)
at WindowsApplication1.Form1.Form1_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(M essage& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Mes sage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
WindowsApplication1
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/HomeSeer%202/Jon00RestartHS_A.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Originally posted by automateme View PostI guess the suggestion is to create a .vbs and use Windows Scripting Host outside of Homeseer.
EDIT: Ahhh... Search is a wonderful thing! I think that I found an old post on how to do this. Thanks for pointing me in the right direction.Mike____________________________________________________________ __________________
Originally posted by Uncle Michael View PostActually, I made the poor assumption that you had a way to inform HS that it was time to shut down. One alternative that might work is the Script Connector plug-in. But it sounds as if Jon has already got a simpler solution.
sponnath
Try version B. I have hard coded the path to Homeseer (C:\Program Files\Homeseer 2\HomeSeer.exe) with this version. See if that now works.
If that fails, it must be something taking ownership of the file, maybe your start-up delayer program.
I don't think the restart software is an issue as it only starts HS on a reboot. But I won''t rule that out. I will do some tests of HS that I have manually started and some started by that software.
Jon,
Just a FYI. I recently began having problems with the RestartHS program. It's been working without a problem for at least a year, but the last couple of weeks it's generated "HomeSeer.exe is already running" or something like that. (Two message boxes.) If I click the two OK's, then start HS, it would restart fine.
I just downloaded the latest version in the first post of this thread, and it worked without the errors. I'm running XP Home, so I didn't really think it would make any difference, but it did.Mike____________________________________________________________ __________________
Oops. Misinformation.
Jon,
Sorry, but I was wrong. My initial success with the new version was a fluke.
I just tried it again and it failed the same way as before. I opened Task Manager and noticed two instances of HomeSeer.exe in the process list. Each disappeared, in turn, when I clicked on the OK buttons in the message boxes. What is more strange is that the program now waits much longer than I would wait before restarting HS.
I stop HS manually by selecting File/Exit from the menu, not by clicking on the red X in the corner. Are the sequences of events different for the two modes?Mike____________________________________________________________ __________________
