I'm in the process of 'upgrading' from PLC to PLM in order to support new devices.
A while after I get everything working, four devices stop showing up in the status tab. They still show as currently registered insteon devices (in manage devices.) If I delete the "In-Linelinc Relay" the other three devices magically reapear in the status list. Re-adding the device and all is fine for a few days until at some point, all four devices eventually disapear, again. They are all in the same "room" catagory. So I did try installing the inlink-relay to another room. It seemed to take longer for the devices to disapear, but once again all 4 stopped showing eventhough they were in different rooms.
There is no rebooting of the computer or restarting of Homeseer in this time. The box running Homeseer does little else (only has a network share and a VNC server). Almost no other applications are loaded. I've only encountered this since installing the PLC - and I have not even installed the new device that I want to support. May go back to the PLM! Any help would be appreciated.
