I am currently running HS3 (3.0.0.96) on Win 8.1 with a Z-Troller and USB adapter and 75 nodes. This setup has worked fine since I converted to HS3 and have had no problems in 9 months and have not made any changes during that time. Suddenly, I can't send any commands--polling, optimization or connectivity test all fail--though connectivity results are not quite stone dead. However, status changes are still being received, so communication is currently one-way only. I have local controllers which also seem to work, controlling local nodes. I also checked each switch by walking around with the Z-Troller and all respond with their node number locally. I changed batteries in the Z-Troller given previous commentary about low battery issues and rebooted the computer. No help.
I see that I am many revs behind on HS3, but am loathe to change anything on a system that suddenly stopped functioning. This failure hits right out of the blue like dead hardware.
Any ideas?
Any ideas?
