for every android device that I want to connect to imperihome do I need to run another instance of the plugin?
multiple devices connecting to imperihome
HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,Tags: None
no, one instance of the plugin can handle as many iOS/Android devices as you want.
one case where you could need several instances of the plugin is for example if you don't want your kids to have access to some devices or events, in this case you can start a specific instance for your kids (don't forget to change the port) and configure it differently.
Originally posted by spud View Postone case where you could need several instances of the plugin is for example if you don't want your kids to have access to some devices or events, in this case you can start a specific instance for your kids (don't forget to change the port) and configure it differently.
Something that does not work in HS Touch is the User Access permissions set per device do not propagate to the HS Touch App. Does this work through this plugin?
Is there a way to add permissions to limit events too? Or is that done by running multiple instances of the plugin?
Thanks in advance,
Jim
