I found some old threads I think might be useful. The bladeplugins website has links that don't work for me. So I can't find if there is any DLdenon documentation out there.
The part of the bladeplugins site that does work are the messages but they aren't any newer than 2011. So I'm thinking that site is not used.
Blade if you don't use it, you should probably remove references to it in the "Sticky" posts.
So I finally broke down and decided to ask for help in the forum.
The source controls don't all work for my receiver. There are several commands I would like to use that aren't available at all. Scripting and hs.Plugin("BLDenon").SendRawCommand command seem to be the answer for any problem I have.
I have found the command list from Denon so everything I could possibly want to do seems possible.
There seems to be some scripting tutorial out there for that is BLDenon specific but I can't find it.
I am new to scripting in homeseer so maybe the answer will just come to me when I start playing with that. Maybe all the devices created by the plugin really don't matter to me and I will just need to script what I want to do.
What I want to do is create a device where setting the value sends that command as SendRawCommand. I could be wrong since I think what I am seeing predates BLDenon and HS3. Not sure how it will work since I have 3 denon receivers registered. But I was thinking the tutorial, if one exists might go into that.
I am looking at the HS3 developer SDK just to see if I could just create a device. I think that a virtual device and an event that executes a script is probably much easier.
But first I need some help on how script to BLDenon.
I am thinking the example is in such an obvious place I missed it. It might be a good idea to add an example to the "description" sticky thread in this forum.
