I don't find Bluetooth as an selection option in the Onkyo - Input device control. When I manually select it at the receiver, the device control indicates Video1, but selecting Video1 in the plugin does not set the input to Bluetooth. Am I missing something? If not, can it be added? Thanks.
Bluetooth Input
So it appears I've created even more of a problem. I chose to delete all devices rather than follow your instructions to the letter--to my detriment. Thought there might be other device updates so why not recreate them all. It then only recreated 5 devices: Status, Power, Muting, Volume and Input. I tried stopping/restarting the PI and then completely deleted it and reinstalled. Even after creating a new receiver, still only those 5 devices are being created. Any thoughts (aside from the obvious that I should follow instructions).-Wade
Here's what I did and the result:
1. Stopped plugin .61
2. Installed beta .62
3. Deleted Zone 1 & Zone 2 input devices
4. Started plugin
Result: 1 device was recreated: Zone 1 input, with only 8 control options (Video1-7, DVD). Zone 2 input device was not recreated.
This seems to be the same result as before.-Wade
Bob, have you had opportunity to further investigate the issue I'm having? On clean reinstall, .62.0 only creates 5 devices, and the Input has only the 8 options noted earlier in this thread Zone 2 isn't created at all, along with most of the other expected devices. This is repeatable. I don't have an older version available to roll back to, so right now the only functionality I have is main zone power and volume, and selection of 8 inputs that I don't use.
Here's my Sys Info and below that an image of the devices it's creating along with the debug log from disabling and re-enabling the PI, in case it's of any help. (I get the error each time I disable the PI, but I don't know what it indicates.)
Thank you.
Wade
System Information
Current Date/Time:
6/22/2018 5:20:14 PM Central Daylight Time
HomeSeer Version:
HS3 Standard Edition 3.0.0.435 (Windows)
HomeSeer:
Is Registered
Operating System:
Microsoft Windows 10 Pro - Work Station
OS Version:
10.0.17134 Service Pack: 0.0
System Uptime:
0 Days 3 Hours 17 Minutes 11 Seconds
User Name and Access Level:
xxxxxxxx (Admin)
LAN IP Address:
192.168.0.30
Client IP Address:
192.168.0.27
External IP Address:
xxxxxxxxxx
Network Adapter:
Adapter -> Realtek PCIe GBE Family Controller IP: 192.168.0.30/24
Network Adapter:
HomeSeer Adapter -> Loopback Address (localhost) IP: 127.0.0.1
Web Server Port:
80
Number of Devices:
205
Number of Events:
47
Event Last Ran:
Motion Control : Den lights Off by NO motion, Ran at 6/22/2018 5:20:07 PM
Number of unique event scripts used:
0
Plug-Ins Enabled:
ImperiHome:,Nest:,Z-Wave:,MyQ:,EnvisaLinkAdemco:,Vera:,Life360:,EasyTrigger:,BLO nkyo:
Processor Type and Speed:
Intel64 Family 6 Model 92 Stepping 9 at 1.40 GHz
Modules/Threads:
134 Modules, 83 Threads
Available Threads:
400
System Processes/Load:
161 Processes, 20% Load
Free / Total Physical Memory:
1.89 GBytes / 3.83 GBytes (49% free)
Free / Total Virtual Memory:
2.19 GBytes / 4.52 GBytes (48% free)
HomeSeer Memory Used:
46 Mbytes
Plug-In Memory Used:
9 EXE Plug-Ins using 106 Mbytes-Wade
Can you do this for me so I have a log of the issue
1. Delete any old debug log
2. Delete the plugin input device for all zones from the device management page
3. Disable the plugin
4. Edit the hspi_BLOnkyo.ini file and change debugLevel=true
5. Save INI file
6. Enable the plugin
Once the plugin is started for 30 seconds or so, then disable debug logging on the options page
Attach the BLOnkyo-Detailed.log zipped
Originally posted by Blade View PostCan you do this for me so I have a log of the issue
5. Save INI file
Attached.Attached Files-Wade
