Error in Startup
    Error in Startup
    Not sure which forum to post to, but I'll start here....
    Getting an error upon startup:
    Compiling script Startup.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
    If this isn't you, just let me know where I should go to ask. Thanks.
    ==JJS==
    Jim Speiser
    38-year veteran of Home Automation
    Still don't know squat
    ==JJS==
    Jim,
    this looks like a generic HS3 issue. I would try the HS3 forum, or the scripting forum is you are modifying the startup.vb script yourself.
    Mark
    HS3 Pro 4.2.19.5
      Originally posted by mnsandler View Post
      Jim,
      OK, no, haven't touched startup.vb.
      But then there's this:
      ***:Error in ProcessGroupBroadcastUpdateDevice: DevIndex=86, GrpNum=10: Index was outside the bounds of the array. -- Details System.IndexOutOfRangeException: Index was outside the bounds of the array. at Insteon.Support.Core.InsteonModule.ProcessGroupBroadcastUpda teDevice(Int32 DevIndex, TransmitMsgType Msg, Int32 GrpNum, Int32 OnLvl, Boolean SyncTarget)
      ** An error occurred in this plug-in. The details have been written to the log file - C:\Program Files (x86)\HomeSeer HS3\Config\Insteon Error Report.Log
      ** To request help with this problem please post this log file to the forum along with a detailed description of what lead to this problem.
      That one I'm pretty sure is you
      Jim Speiser
        sure. what is [Device 86] in the insteon.ini? the error is suggesting it sent a msg from Group 10
        Mark
        HS3 Pro 4.2.19.5
          Hmmm...interesting. It's the guest bedroom mini-remote...which I have never implemented and never fully configured.
          [Device 86]
          ChannelName1=A - Overhead Light
          ChannelName2=B - Overhead Fan
          ChannelName3=C - Painting Light
          ChannelName4=D - Hall Light
          ChannelName5=E - Bath Light
          DatabaseDelta=12
          DeviceID=44.8A.F8
          DeviceLocation=Guest Bedroom
          DeviceName=Mini Remote
          DeviceType=001A
          EEValues=RBPMask=0,OpFlags1=22
          FailedInteractions=0
          FirmwareVer=39
          HopData=310,301,4,5
          LastContact=11/22/2017 1:33:57 PM
          Link 1=E2 02 3D 98 D6 00 00 02 1
          Link 10=E2 01 18 37 3C 00 00 01 10
          Link 11=E2 04 1A 87 A5 00 00 01 11
          Link 12=E2 06 24 60 B9 00 00 01 12
          Link 2=E2 01 3D 98 D6 00 00 01 2
          Link 3=E2 04 3D 98 D6 00 00 04 3
          Link 4=E2 03 3D 98 D6 00 00 03 4
          Link 5=E2 06 3D 98 D6 00 00 06 5
          Link 6=E2 05 3D 98 D6 00 00 05 6
          Link 7=E2 08 3D 98 D6 00 00 08 7
          Link 8=E2 07 3D 98 D6 00 00 07 8
          Link 9=E2 02 17 8E 70 00 00 01 9
          LinksDownloaded=1
          NumLinks=12
          PollingInterval=0
          Protocol=3
          RecentDatabaseDelta=12
          SyncLinkedDevices=0
          TotalInteractions=30
          Jim Speiser
            [Device 86]
            DatabaseDelta=12
            DeviceID=44.8A.F8
            DeviceType=001A
            FirmwareVer=39
            HopData=310,301,4,5
            LinksDownloaded=1
            NumLinks=12
            PollingInterval=0
            Protocol=3
            SyncLinkedDevices=0
            so in this case the remotelinc doesn't have a group 10. its a error in the message. Maybe i should just log it as opposed to throwing an exception.
            Mark
            HS3 Pro 4.2.19.5
              Do you want to see the error report log?
              Jim Speiser
                And why would it throw anything if it is locked in my office and not being used?
                Jim Speiser
                  please post the error report log file so i can see the specific msg that generated the error
                  Mark
                  HS3 Pro 4.2.19.5
                    See upload.
                    Jim Speiser
                      Jim
                      from your log
                      6/17/2018 7:08:34 PM - Received STX 0x50 (Raw Insteon Rec):44 8A F8 00 00 0A C3 14 00
                      the 14 00 would indicate a fast off was sent from the remote
                      this is an invalid broadcast msgs from the remote.
                      lets monitor it for now and see how frequent it happens
                      Mark
                      HS3 Pro 4.2.19.5
                        Acknowledged. Will monitor log for re-appearance of anomaly.
                        Speiser out.
                        Jim Speiser
