spud I installed kodi alpha 2 v18 and there seems to be a small problem in the plugin. the plugin is not consistent in detecting when kodi is playing. sometimes the plugin will detect what is playing after you hit the pause button, but then you hit play again and it does not see kodi is playing again. could you take a look?
kodi alpha 2 v18
Originally posted by wadesready View Postspud I installed kodi alpha 2 v18 and there seems to be a small problem in the plugin. the plugin is not consistent in detecting when kodi is playing. sometimes the plugin will detect what is playing after you hit the pause button, but then you hit play again and it does not see kodi is playing again. could you take a look?
Sent from my SM-G950U using Tapatalk
Originally posted by Ltek View PostThis problem started with Alpha 1. Much of the functionality is broken. It never registers what is playing and half the time it doesn't 'see' that it is playing something at all so it never registers as playing.
I knew it was broken since alpha 1, but spud said he would take a look at it when alpha 2 came out.
Please test version 3.0.1.12 available here: https://forums.homeseer.com/showthre...63#post1078363
thanks
Originally posted by spud View PostPlease test version 3.0.1.12 available here: https://forums.homeseer.com/showthre...63#post1078363
thanks
I tried dis-abling and with kodi enabled...both installs fail.
I got it spud...but I had to extract it into the folder in the updates3 folder to get it to install
appears to be working! thank you spud!!!Last edited by wadesready; June 26, 2018, 06:50 PM.
