Planning to put a leak sensor in the attic where our steam generator is going to be installed. All the ones I see uses battery. There's no define listing on the sensors stating how long a battery should last. I'd hate to have to crawl up the attic to replace the battery every few months.
Any AC powered leak detector or long lasting battery ones?
Here I have a leak detector wired into my furnace that is setup to stop the AC in the event water is detected. I wired a relay in and setup the second circuit to close in the event that the primary water sensor opens the circuit. I tied a Zwave dry contact sensor to the secondary relay. Works like a champ.
Originally posted by dannieboiz View PostPlanning to put a leak sensor in the attic where our steam generator is going to be installed. All the ones I see uses battery. There's no define listing on the sensors stating how long a battery should last. I'd hate to have to crawl up the attic to replace the battery every few months.--------------------------------------------------
**** Do You "Cocoon"? ****
Guest
Fibaro flood detector supports optional AC power adapter. In that case battery serves as backup only when power is cut short, and lasts for years.
https://www.fibaro.com/en/products/flood-sensor/
Danny, I originally bought these from HS and then from Lowes https://www.lowes.com/pd/Utilitech-W...Sensor/4740940. I have a dozen over 10 years and have them in difficult places like attic, behind washing machine and in crawlspace. I convert them to AC power with a tiny DC-DC variable circuit board that I install in the battery bay and then connect any old spare AC-DC power supply to it - as long as it's more than 6VDC output it will convert down to the required 4.5VDC battery replacement level. I do the same with ST814s.All Z-Wave, #101 devices, HomeTroller Series2, HomeSeer2 v.2.5.0.81, & 1x Z-Troller
Fibaro Sensor
I have a few of these in my underfloor space. They do not have to detect a flood directly but with a wire extension can detect a flood remotely. My wired sensor extension is on a wooden pole and the sensor wire is placed about 3 cm (1 Inch) above what I consider a reasonable level of water. Our water table is quite low.
The sensor which is remote senses the water level when the water reaches the two wires. I have a 12 VDC supply powering the sensor and sump pump. Saves lifting the carpets.
Hope that helps.
Jo
