Yes, I'm perfectly comfortable in testing this. It seems like it fixed the error but now we have a new one: Details: error VBNC30456: 'Count' is not a member of 'System.String[]'.
Z-Wave Lock Events Script - Discussion Thread
Originally posted by Igorski88 View PostYes, I'm perfectly comfortable in testing this. It seems like it fixed the error but now we have a new one: Details: error VBNC30456: 'Count' is not a member of 'System.String[]'.
Code:If PluginList IsNot Nothing AndAlso PluginList.Count > 0 Then
Code:If PluginList IsNot Nothing AndAlso PluginList.Length > 0 Then
AlHS 4.2.8.0: 2134 Devices 1252 Events
Originally posted by Igorski88 View PostGREAT, it fixed the issue. But unfortunately now its coming back with a new msg: 'VbCrLf' is not declared. It may be inaccessible due to its protection level.
Sorry to bother you with this again!
- add a line near the top under "Try"Code:Dim VbCrLF As String = Chr(10) & Chr(13)
If you get more errors after that, I'll need to find a linux system to try it on. For the interim, it would be best if you grabbed a copy of your script from your other system and used it. Thanks for your patience!
Cheers
Tried a couple of different things:
AddingCode:Dim VbCrLF As String = Chr(10) & Chr(13)
So I went with option number 2:
I replaced all the "& VbCrLf" with empty text and the error went away
and I started to receive a new error: "Replace is not declared"
So I then undid option # 2 to try the following:
I added the following to the very top.Code:<%@ Import Namespace="Microsoft.VisualBasic" %>
But now im stuck with: Value of type 'Object' cannot be converted to 'System.String[]'.
So yes I do understand that some testing may need to be done on a Linux device. If there is anything I can do to help you with that please know that "i'm in".
If you get more errors, can you post them?
AlLast edited by sparkman; March 19, 2017, 07:34 PM.HS 4.2.8.0: 2134 Devices 1252 Events
Originally posted by Igorski88 View PostMan you work fast!
I updated both and the doorlock.aspx spit out: error VBNC30451: 'Split' is not declared. It may be inaccessible due to its protection level.
Can you add the reference to visual basic back in as a test?
I had updated the split command as some versions of mono don't like .split, so I used Split() instead. Split is a VBScript command in theory, so should not work on any versions of mono, but it works on mine without the reference to visual basic. Also, can you try running the script file to see if it returns any errors?
Well I hope you get better soon!
After the Vb reference it get rid of the "split" error and spits out: error VBNC30311: Value of type 'Object' cannot be converted to 'System.String[]'.
The script spits out one error as opposed to the 5 before your update: Running script /usr/local/HomeSeer/scripts/doorlock.vb :Exception has been thrown by the target of an invocation.Cannot find the requested class member.
In the script file, can you change:
Code:Dim ValueAction() As String = Split(ValueAction2,"|")
Code:Dim ValueAction() As String = ValueAction2.Split("|")
I'll have to figure out why aspx files are not running on my system at all. The error messages have all been pretty strange.
Cheers
YOU ARE THE MAN! doorlock.aspx officially works on Linux.
The script however is still throwing a "Running script /usr/local/HomeSeer/scripts/doorlock.vb :Exception has been thrown by the target of an invocation.Cannot find the requested class member." error.
Please drop me your venmo username or PayPal email in a privet msg I'd like to buy you a beer!
Originally posted by Igorski88 View PostYOU ARE THE MAN! doorlock.aspx officially works on Linux.
Cheers
Originally posted by sparkman View PostGreat and thanks for the offer. I'll take you up on that when we get the script part is also working . The aspx page doesn't do you any good without a working script. Can you post a screen shot of your event that you are using to call the script?
Cheers
Al
Sent from my SM-G935V using Tapatalk
The script needs to be called with one parameter, which is the name of the door. See the first screen shot in this post: https://forums.homeseer.com/showpost...47&postcount=1. It should trap that in the script though, but can you try that and see if it makes any difference?
