Originally posted by mnsandler
View Post
Apr-10 3:51:02 AM Vista Alarm Setting System to Faulted Apr-10 3:50:58 AM Vista Alarm Error: System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource) at System.Collections.Generic.List`1.get_Item(Int32 index) at HSPI_VistaAlarm.VistaAlarmClass.ZonesCollection.UpdateClearedZones(MessageCollection& Messages, Boolean BypassMode, PartitionClass Partition) at HSPI_VistaAlarm.VistaAlarmClass.ProcessMessage(String Buffer) [3.0.0.27] Apr-10 3:50:58 AM Vista Alarm Zone changed. Set device Vista Zone 16 to Value=Normal Apr-10 3:50:58 AM Vista Alarm Trouble handling last msg: [00000001100000000A--],010,[f70000871010000028020000000000],"FAULT 10 GARAGE DOOR " Apr-10 3:50:58 AM Vista Alarm Zone changed. Set device Vista Zone 10 to Value=Fault Apr-10 3:50:58 AM Vista Alarm MessageKey=FAULT-10 Apr-10 3:50:58 AM Vista Alarm Processing msg on Partition 1 Apr-10 3:50:58 AM Vista Alarm [00000001100000000A--],010,[f70000871010000028020000000000],"FAULT 10 GARAGE DOOR " Apr-10 3:50:58 AM Vista Alarm Setting System to Faulted Apr-10 3:50:54 AM Vista Alarm Zone changed. Set device Vista Zone 18 to Value=Fault Apr-10 3:50:54 AM Vista Alarm MessageKey=FAULT-18 Apr-10 3:50:54 AM Vista Alarm Processing msg on Partition 1 Apr-10 3:50:54 AM Vista Alarm [00000001100000000A--],018,[f70000871018000028020000000000],"FAULT 18 LIVING WINDOW 1 " Apr-10 3:50:54 AM Vista Alarm Setting System to Faulted Apr-10 3:50:50 AM Vista Alarm Processing msg on Partition 1 Apr-10 3:50:50 AM Vista Alarm [00000001100000000A--],017,[f70000871017000028020000000000],"FAULT 17 KITCHENWINDOW " Apr-10 3:50:50 AM Vista Alarm Zone changed. Set device Vista Zone 17 to Value=Fault Apr-10 3:50:50 AM Vista Alarm MessageKey=FAULT-17 Apr-10 3:50:50 AM Vista Alarm Setting System to Faulted Apr-10 3:50:46 AM Vista Alarm Error: System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource) at System.Collections.Generic.List`1.get_Item(Int32 index) at HSPI_VistaAlarm.VistaAlarmClass.ZonesCollection.UpdateClearedZones(MessageCollection& Messages, Boolean BypassMode, PartitionClass Partition) at HSPI_VistaAlarm.VistaAlarmClass.ProcessMessage(String Buffer) [3.0.0.27] Apr-10 3:50:46 AM Vista Alarm Zone changed. Set device Vista Zone 18 to Value=Normal Apr-10 3:50:46 AM Vista Alarm Trouble handling last msg: [00000001100000000A--],016,[f70000871016000028020000000000],"FAULT 16 OUTSIDEGARAGE DOOR " Apr-10 3:50:46 AM Vista Alarm Zone changed. Set device Vista Zone 17 to Value=Normal Apr-10 3:50:46 AM Vista Alarm Zone changed. Set device Vista Zone 10 to Value=Normal Apr-10 3:50:46 AM Vista Alarm Processing msg on Partition 1 Apr-10 3:50:46 AM Vista Alarm [00000001100000000A--],016,[f70000871016000028020000000000],"FAULT 16 OUTSIDEGARAGE DOOR " Apr-10 3:50:46 AM Vista Alarm MessageKey=FAULT-16 Apr-10 3:50:46 AM Vista Alarm Setting System to Faulted Apr-10 3:50:44 AM Vista Alarm Monitor started... Apr-10 3:50:43 AM Vista Alarm Loading Relay Devices... Apr-10 3:50:43 AM Vista Alarm Found the AD2USB on port COM4 running firmware version V2.2a.8.4c Apr-10 3:50:43 AM Vista Alarm Received msg: !VER:000006db,V2.2a.8.4c,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB;DS;ER Apr-10 3:50:43 AM Vista Alarm Sent cmd: V Apr-10 3:50:43 AM Vista Alarm Opened COM port COM4 Apr-10 3:50:43 AM Vista Alarm Loading the Partitions
