I was moving one Nodemcu board from the PC USB power to the USB outlet and I noted that the board would not reconnect, I tried reconnecting but it would not connect. I decided to plug back to the PC USB and Upload the API again. It connected fine, then I moved it to the power USB outlet and now is connecting fine. I think this happened with the other two boards that right now are in disconnect status. I will post my results when I will update the other two.
Aldo
Aldo
