I have another plugin which insists on & device codes - ML doesn't like it and BL2HS ignores them - I see them in the list to choose to send to ML, but ML variables are not created.
Is there any way to map device codes to a custom value? It would be great to default to the device code, but allow the user to override the device code and specify the variable "section" in ML.
For instance if I have a device for my mailbox sensor and that device code is &1, then when I check that, the plugin would default to using that &1 - but, I can override it either in the config file or the UI by typing my own code/name.
