I made a quick test with a 9 vots battery and a 220 ohm resistor and it's working!
Rigth now I guess the home power consuption should be arround 2.5 kWh. The counter is increasing in 1 minute from E2 03 to 0F 04 (45 pulses) and in 5 minutes to 92 04 (176 pulses), so if the output is 1000i/kWh in the first minute the power was 2.7 kWh (45*60/1000) and in the second 2.112 kWh (127/5*60/1000).
Now I turn off a heat pump with the counter at 38 05 in 1 minute it goes to 42 05 (10 pulses) and in 5 minutes to 67 05 ( 47 pulses), so if the output is 1000i/kWh in the first minute the power was 0.6 kWh (10*60/1000) and in the second 0.564 kWh (47/5*60/1000).
It looks like it works!!!!
This was done with the OneWireViewer son now I just have to integrate it with mcsTemperature (and redo it for the definitive instalation) and work in the web page to show the values.
REM: By mistake I connected for about 1 minute a 22 ohm resistor instead of the 220 ohm and everything is still working. Ufff...
MANY THANKS YOU ALL (specialy Peter, Jon and Rocco)
