Hi All,
Btraced Track and Trace for the iPhone is in the appstore and the Androidstore now.
Nice thing about Btraced is that its intentially designed for use within home automation.
the app can send an XML to your own server of choice.
With the use of a script (asp/asp.net etc.) you can import this in HS.
You can use it to see if you are coming closer to your home, switch devices and inform your wife :-)
sample asp or php scripts available to receive the XML on your HS server, but HS functions will work also!
Check the features on www.btraced.com and http://forum.btraced.com
Android store:
https://play.google.com/store/apps/d...id=com.btraced
Appstore:
https://itunes.apple.com/app/btraced/id498853172?mt=8
Best Regards Bwired
Android store:
Appstore:
Best Regards Bwired
