Problem controlling Somfy RTS with 2 RFXcom
    I have 2 RFXtrx, one of them paired to a Somfy RTS blind. Thats working fine. As that Rfxtrx is on a unreliable USB over ethernet, I thought I switch transmitters on the device to the other Rfxtrx (obviously left the code unchanged). But it does not respond when I try to control it. Do I have to pair it to the second Rfxtrx even though it has the same code ?
    You need to pair each RFXtrx433E with a different ID-Unit Code to the Somfy motor.
    The reason is that the rolling code for each ID-Unit Code is stored in the RFXtrx433E.
    If you use another RFXtrx433E with the same ID-Unit code the rolling will not match and the motor will not respond.
      Ok that makes sense. But I cannot use the same code to pair to the second Rfxtrx, I have to give it a different one ? Then I could easily switch transmitters if needed
        Yes, you have to use a different code.
        The Somfy motor can have a few remotes paired. Each Somfy remote has a different ID.
        The RFXtrx433E act as a Somfy Telis4 remote.
        The motor has an internal table for each paired remote with: ID, unit code, rolling code.
        For that reason you cannot use the same ID, unit code in a different RFXtrx433E.
