Here is an X10 Camera cycling script that cycles five x10 cameras (codes A1 through A5) based on an entered time interval and starting time, (# of minutes past the hour).
It assumes that you are using a webcam application, and controls the signal that is being passed to the application.
This script ensures that the each camera will be turned on 2 minutes prior to the defined starting times each day, with each subsequent cameras being turned on after the # defined in time_cycle.
