Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > MCS Plug-Ins and Scripts > mcsSprinklers
  #41
Old August 6th, 2017, 02:55 PM
cjin cjin is offline
Seer Deluxe
I noticed some problems in v2.17.0.11 for .NET 2 you posted, although they are not directly related to the rainfall data issue:
1) on Other Setup tab, it only show Basic and Standard version. The pro version is no longer visible.
2) on Area setup tab, most of the settings are no longer visible.
3) On General Status tab, weather forecast/UV etc no longer get updated although on Weather Setup tab the I can display correct forecast info when click on Evaluate Internet Download button.
  #42
Old August 6th, 2017, 09:22 PM
Michael McSharry's Avatar
Michael McSharry Michael McSharry is offline
OverSeer
Look at Other Page. Is P:rofessional option available? At the bottom is expert mode available? If so select both of these.
  #43
Old August 7th, 2017, 03:57 AM
Seer Deluxe
Quote:
Professional options isn't available. At bottom of the Other page, only expert mode context help is available and already selected.
  #44
Old August 7th, 2017, 05:23 PM
OverSeer
All we are trying to do is look at the hourly moisture calculation which queries the rain information from the database. The license key is HST magic so not able to easily investigate, but should not matter. If the test does not provide the data we need then other investigation of the variance in operation can be researched.
  #45
Old August 8th, 2017, 02:41 AM
Seer Deluxe
Understood. Please see attached debug file. Some of the RainLastHouse numbers don't look right. Thank you Michael.
  #46
Old August 9th, 2017, 06:17 PM
OverSeer
I see the error in the implementation. In your case we have two problems to solve because of the .NET 2 build not working the same at the .NET 3.5 build. I'm not certain where to start, but let us first understand why the plugin version is not aligning. I am not certain what I will learn, but there is also a startuptrace.txt file in what is likely the \data path that will contain the startup information. Please post it.
  #47
Old August 9th, 2017, 08:10 PM
Seer Deluxe
Thank you Michael. Please see attached startuptrace.txt file. It is in \data but time stamp on the file was from 2013, so I am not sure if it will give useful information.
File Type: zip StartupTrace.zip (596 Bytes, 1 views)
  #48
Old August 12th, 2017, 02:27 PM
OverSeer
After looking at the code my best guess is that you also have the Standard plugin available and the plugin looks for the first one it finds. I did add debug while this iteration is being done. I also changed the algorithm for hourly rainfall. These updates are attached.
  #49
Old August 12th, 2017, 11:16 PM
Seer Deluxe
I originally had Standard plugin then upgraded to Pro. Should I remove standard plugin and not just disable it?
  #50
Old August 13th, 2017, 12:09 PM
OverSeer
mcsSprinklers uses the HS2 API call to get the set of plugins. I do not recall if HS2 returns all plugins found or all plugins enabled, but you can easily deal with it by renaming with something other than HSPI at the start.
  #51
Old August 17th, 2017, 10:15 AM
Seer Deluxe
Michael, thanks for building the .NET 2 version. Here are some observations:
What work correctly:
1) settings for Pro version now all show up correctly.
2) weather update download works fine
It seems earlier problem was related to an older out of date Standard version was activated.
Remaining problems:
1) on Zone status tab, displayed moisture % decreases with calculates ET which looks reasonable, except rain data was not taken into account. So it behaves as if there is no rain, regardless what rain sensor is reporting.
2) on General tab, rain sensor displays today's rain data correctly
3) on General tab, moisture % for all the zones stay constant and never change (so they deviated from the moisture % on Zone status tab). They all retain an old time stamp and never get updated.
I posted debug file for Aug 14. The rain fall started around 9:23am in that day.
Thanks again.
File Type: zip mcsSprinklers_GeneralDebug8_14_2017_12_00_29_AM.zip (216.7 KB, 2 views)
  #52
Old August 19th, 2017, 12:28 PM
OverSeer
Lets try this one. Don't know why I did not see problem when testing last one.
  #53
Old August 20th, 2017, 12:04 PM
Seer Deluxe
Michael, I see the same problem still exists:
Moisture % on. Zone status changes with calculated ET but moisture % on General tab stuck at the same level.
I am away from the house so haven't got a chance to pour water in raiun sensor to test, will report back when it rains.
Also on Evaluate internet weather download screen (Accu weather zip mode) what is the difference between Rain x100 and "Forecast"?
  #54
Old August 20th, 2017, 05:26 PM
OverSeer
I did not see any problem with updating the General Status zones as moisture level changes. I moved some debug around. I also incorporated the other recent changes primarily associated with weather data download. The latest is at:
http://mcsSprinklers.com/MCSSPRINKLERS_217014_Net2.zip
Accurweather delivers forecast rainfall rather than forecast rainfall percentage that exist with other sites. It is scaled up by 100 to keep it an integer value.
  #55
Old August 23rd, 2017, 01:51 AM
Seer Deluxe
Michael, I am having problem downloading this file. It appears only a link was included but the file itself was not uploaded. Can you please upload it again? Thanks.
  #56
Old August 23rd, 2017, 07:59 PM
OverSeer
Looks like a bad upload. Redone and confirmed with download.
HTML code is Off
Soil Moisture gearyt Ultra1Wire2 HSPI 9 November 23rd, 2016 04:56 PM
Soil Moisture Sensors Mael mcsSprinklers 1 March 21st, 2014 07:43 PM
Soil Moisture Pete mcsSprinklers 8 August 16th, 2010 12:21 PM
Soil Moisture sensors caustin mcsSprinklers 1 June 25th, 2007 02:47 PM
Soil moisture / DS 2760 couchounou MCS Temperature 1 April 23rd, 2006 07:17 PM
