Just switched over to HS3 a few months ago and thought I would add in the RR501 (I use it to capture the remote control signal as a trigger). In HS2, X10 used to be an explicit trigger option. I've searched and searched and can't find a way to set up an X10 device using the Homeseer plugin.
When looking at the logs, my 2413U is capturing the noise as below:
Aug-22 12:03:41 HSInsteon DEBUG WARNING: Discarding 8 bytes '02 52 66 00 02 52 62 80'
Aug-22 12:03:41 HSInsteon DEBUG WARNING: Could not process data '02 52 66 00 02 52 62 80'
Aug-22 12:03:41 HSInsteon DEBUG WARNING: Could not read the expected number of bytes from the serial port; Expected=1, Received=0, Timeout=1000ms
Aug-22 12:03:40 HSInsteon DEBUG WARNING: Skipping 4 bytes to '02 52 66 00 02 52 62 80', discarded '02 52 66 00'
Aug-22 12:03:40 HSInsteon DEBUG WARNING: Could not process data '02 52 66 00 02 52 62 80'
Aug-22 12:03:40 HSInsteon DEBUG WARNING: Could not read the expected number of bytes from the serial port; Expected=1, Received=0, Timeout=1000ms
Aug-22 12:03:39 HSInsteon DEBUG RX: 02 52 66 00 02 52 62 80 (appended)
Aug-22 12:03:37 HSInsteon DEBUG RX: 02 52 66 00
I just can't figure how to create an event based on this. Setting up a generic device with an A1 code (which is what the RR501 is set to) doesn't seem to work. Installing an X10 plugin doesn't make sense as I'm using the Insteon plugin to communicate with the X10 device. Humph...is it not possible?
