In the HS log is the "All Devices Updated" still supposed to have an entry every minute or not?
Coming Soon: Life360 Plugin
Originally posted by cowinger View PostIn the HS log is the "All Devices Updated" still supposed to have an entry every minute or not?
I left the 1 entry just to know things were still alive/working. If the 1 log entry is still too much I can move it to debug as well.
Originally posted by jeubanks View PostYes. It logs 1 entry per update interval. If you change your update interval to 5 minutes you will then get 1 log entry every 5 minutes.
Originally posted by cowinger View PostIt is fine I was just wondering if it was supposed to be doing that still. As long as it doesn't interfere with another event trying to run at that same time. It would be very rare but might be possible.
However once this is out of initial dev/test stages I may move all but initialize logging into debug. Nobody needs useless log messages.
Originally posted by jeubanks View PostI would find it very hard to see a log call from a separate thread interfering with a HS3 event call. I suppose it is possible but that would mean there's some major issues with the HS3 plugin api.
Originally posted by cowinger View PostI agree it would be very rare if it ever happened. I wasn't sure if they could be related or not. I don't know much about it. Otherwise it is working great.
Originally posted by jeubanks View PostOnce I'm a little more sure about things working then I'm going to move all of the logging to debug except the initialize messages on startup.
Originally posted by cowinger View PostThat sounds great. By the way I sent another message through the app to Zsane. I asked about the 15 min interval time for detecting changes and if it is being looked at or not. Also I asked him if the zone sizes could be a little more adjustable or have more choices to choose from. I will report when I hear, if I hear.
The zones used to be a lot more options in their sizes. Some of the changes they have made are not for the better, but I think they restricted the zone sizes due to the problems with accuracy and update times they have on their end.
Update: 0.0.2.93
Fixed Plugin not saving configuration properly
Fixed Places configuration not being saved and reused on restart
Removed unnecessary logging
https://forums.homeseer.com/showpost...98&postcount=1
Originally posted by deanrparry View PostAnybody know the minimal time interval for refresh so api does not block me? currently left it at the default 1 minute until reassured
Something has happened in one of the last updates.
Plugin is disconnecting every minute:
Log: Plugin Life360 with instance: has disconnected
Log: I/O interface Life360 is down, executable is not running, restarting ...
Tried deleting all config files and installing the latest version again (2.93)
But now I can't recreated the devices again, getting following error message:
Posting back to plugin web page Life360Config: Exception has been thrown by the target of an invocation.-> Server stack trace: Exception rethrown at [0]: at (wrapper managed-to-native) System.Object:__icall_wrapper_mono_remoting_wrapper (intptr,intptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI:PostBackProc (string,string,string,int) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <03c63de3f1dc4fe5b4c97ebd223f29dc>:0
I am still on linux
Originally posted by cp1983 View PostSomething has happened in one of the last updates.
I am still on linux
When you said you deleted all configuration files did you also delete Config/Life360
Are the permissions set correctly on Config/Life360 for the plugin to write it's files to that directory?
I'm trying to figure out that error is there more in the debug log? Can you enable debug and let it run to see if more info is gathered?
I've been running 0.0.2.93 since release and I haven't had any of those errors on Linux. I'm running Linux (Ubuntu 18.04 Server) with latest Mono from the mono project.
What version of HS3? I'm running .435
