Am I the last man standing who is using RadioRA (1) with Homeseer? With HS3 coming you know if you are there with me, then you and I will be out of luck as HS3 will not have support for RadioRA. HSPRO had it as part of the core, which is one reason I went that way, but the plugin was written in VB6 (COM) which is not supported in HS3.
There is an option for us though. The source code for the original plugin can be purchased and then converted to .NET. Is anyone interested in this? I have a 30 zone RA system that has been working great with HS for years and I am happy with the hardware, but if a plan is not hatched soon, then you and I will be left out of HS3 all together.
Consider this a call to arms....if you still use RadioRA please speak up to at least let us know you're still out there.
