Kinect Plug-in Features
What hardware does this require?HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
A good VR working interface would also be nice.
I would probably use it to manage the multimedia stuff in the family room; simple stuff; then again even a hand gesture would be better than using the remote....
I never have utilized Homeseer VR but did play with TTS stuff in the 80's and 90's; today though I have it shut off in two vehicles because it was annoying me.
Kind of what CastleOS is doing would be nice...
http://www.castleos.com/- Pete
wow I cant wait for this. If you need a Beta tester then I am here to help.
I would love this to do VR , gesture and posture recognition.
Keep up what looks like great work.
Greig.Zwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
I don't own a kinect device, but if I could put one in the master bedroom and it could tell we're all asleep, ignore all cat activity, and turn off the lights either by VR, gesture, or 5 minutes after we fall asleep, and dim to 20% if we get up from the bed, that would be pretty awesome.
I can do some of this now with motion sensors and VR and some trickery, but really, the entire reason I started home automation was to do what I just stated above.... The rest of the stuff that I've added over the years, that's jsut gravy (icing on the cake).
If the kinect can wirelessly be connected to the HS server, would this be strictly HS2 or HS3 or would it be multi-version capable?huggy_d1
Automating made easy
Originally posted by huggy_d1 View PostIf the kinect can wirelessly be connected to the HS server, would this be strictly HS2 or HS3 or would it be multi-version capable?
The kinect needs to be connected to a win7 or win8 machine on which the plugin would be installed. HS3 supports remote plugin, so the kinect machine is not necessarily the HS server.Last edited by spud; September 25, 2013, 05:20 PM.
Originally posted by langenet View PostWhat hardware does this require?
- Kinect for Xbox 360
- Kinect for Windows
They are almost the same hardware, but Kinect for Windows supports additional features (like near mode) but is more expensive.
Kinect for Xbox 360 is not officially supported to work connected to a PC, and the kinect runtime will not work with this version.
From Kinect FAQ
The Kinect for Xbox 360 sensor was built for and tested with the Xbox 360 only, not with any other platform, which is why it is not licensed for general commercial use, supported, or under warranty when used on any other platform.
This is the version I have to develop this plugin and it works great. I just get a warning in visual studio:
The Kinect sensor plugged into your computer is for use on the Xbox 360.
You may continue using your Xbox 360 Kinect sensor on your computer for development purposes.
Microsoft does not guarantee full compatibility for Kinect for Windows applications and the Xbox 360 Kinect Sensor.Last edited by spud; October 8, 2013, 07:42 AM.
Will this support more than one connect?
Will this support multiple plugins on different computers with connects attached?Zwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Originally posted by enigmatheatre View PostWill this support more than one connect?
I have the xbox 360 version of kinect . I thought I had to go to the PC version to utilize this with HS. I started some code but time does not allow it. I would be more than happy to beta test. My main HS2 box is win 7.
I had the VR and Cam working with HS 2 and thats as far as I have got it. It has an array noise cancelling mic setup which did work very well with HS.
VR and people recognition would be high on the list.
Ability to lock system until admin is recognized.
Sitting or standing recognition could be utilized uniquely too.
Pet recognition?
I'm willing to "donate" to help to bring this to fruition.3.0.0.548: HS3PRO - 3.0.5.10: AIAlert - 2.1.1.0: APIWeather - 2.0.64.0: BLBackup - 2.0.45.0: BLLAN - 2.0.37.0: BLRoombaWifi - 1.0.0.3: DevLog - 1.2.5.15: KeyPad - 3.0.2.25: NetCAM - 0.0.0.52: Pushover 3P - 3.0.0.5: SendVFD - 1.0.0.3: Tiles - 3.0.11.0: Z-Wave
Originally posted by huggy_d1 View PostI don't own a kinect device, but if I could put one in the master bedroom and it could tell we're all asleep, ignore all cat activity, and turn off the lights either by VR, gesture, or 5 minutes after we fall asleep, and dim to 20% if we get up from the bed, that would be pretty awesome.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Good VR seems to be the most wanted, so that's what I'm going to work on next. Once it's done I will post a Beta version of the plugin.
If you don't know what is Bitcoin, google it and read about it, it's very innovative and interesting stuff.
