OK. That worked. Lets see whats next. I will update soon.
Got Siri Working with HomeSeer!
I have edited the siriproxy-example.rb file to include this statement:
listen_for /Bedtime/i do
say "You got it Jay"
end
request_completed #always complete your request! Otherwise the phone will "spin" at the user!
end
However, siri doesn't recognize it. The other example statements it does recognize. Is there something I'm doing wrong. Is there a different way I should be editing that file. It's like the server doesn't even see the phrase bedtime and in fact it comes up as no matches.
I'm at about the same point. I got the message "Siri Proxy is up and running" w/o the bundling because I was using the downloaded fully configured VMWare Appliance and the Step 7 Bundler action appeared only inthe Main Install portion of the instructions.
I think my problem has to do with the DNS pointing. Is the only change to put the virtual machine's IP address in the DNS position of the phone's Wifi settings? Do the other addresses already there remain? It doesn't seem to make any difference. Siri proxy server doesn't respond when I do the testing...
I made a similar change in the example file and it was like it wasn't there. I restarted the virtual appliance and the change was there. So there must be a way or command to update the file with out a restart.
I also could not do a sudo reboot, sudo halt or anything. I had to force a restart of the VM player - thats not good.
Originally posted by cbarner View PostI'm at about the same point. I got the message "Siri Proxy is up and running" w/o the bundling because I was using the downloaded fully configured VMWare Appliance and the Step 7 Bundler action appeared only inthe Main Install portion of the instructions.
Originally posted by X10joe View PostI made a similar change in the example file and it was like it wasn't there. I restarted the virtual appliance and the change was there. So there must be a way or command to update the file with out a restart.
I also could not do a sudo reboot, sudo halt or anything. I had to force a restart of the VM player - thats not good.________________________
Dell Zino HD - HSPRo 2.x
HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
2 x Brultech ECM1240 with UltraECM
USB UIRT
Cooper Aspire Z-Wave Switches
WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
HM ST812-2 Flood Sensor
HSM100 - Motion Detector with Light and Temperature
2GIG Thermostat
BLDSC - Alarm Plug-in
BLUPS
UltraLog (SQL2008)
Jon00 Plugins
Host XR3 BT and Jon00 BT Proximity
Global Cache IP2IR
Foscam FI8918W
Originally posted by mark_anderson_us View PostYou need to read part 1 it tells you exactly what to do after changing the config file
Worst case do su -
Then reboot________________________
USB UIRT
2GIG Thermostat
BLUPS
UltraLog (SQL2008)
Jon00 Plugins
Global Cache IP2IR
Foscam FI8918W
Originally posted by mark_anderson_us View PostI use sudo halt all the time
Worst case do su -
Then reboot
