I had 28 UPB dimmers pop during a power outage, and I decided to begin a move to Z-Wave since I have to replace these dimmers anyway. After much research I decided that the WD100+ looked very promising, due to instant status and the double/triple click functionality. I have installed two of these devices as a test, and I've come across what I fear may be a fatal problem...
I'm very happy with how the dimming of the switches works. Holding the paddle changes the brightness at a very reasonable rate. The three second fade on and off, however, will absolutely not pass the WAF test. When we turn the light on or off, we want it to be instant.
I'm really hopping someone can tell me that I'm wrong here... The manual dimming rate and the fate rate for turning the light on and off seem to be controlled by the same pair of settings (Ramp Rate for Local Control). Is there something I'm missing? How can I maintain the default dimming behavior but have instant on and off?
Assuming, as I fear, that there is no way around this, is there any hope of a firmware update that will give me what I want? I'm currently using 5.16. I would argue that on/off fade rate and manual dimming rate are totally different things, and one shouldn't have to change one in order to change the other.
