PWM Dim Time
    PWM Dim Time
    Just wondering if there is a way to control the amount of time beyond 5sec for the PWM fade function. I was loolking to see if I can have variable dim setting between 0 to 120 minutes?
    THanks
    Mark
    THanks
    Mark
    Hi Greig,
    Can you let me know if this is possible?
    Mark
      Hi Greig,
      Mark
      Mark,
      Sorry I missed the first post.
      This not possible as I am using a library that only supports up to 5sec. You could do this is a HS script to notch the level down 1% over the time you need if you still wan to do it that way.
      Greig.
      Scripts =
      Various
        Mark,
        Greig.
        Super, thank you!
