I haven't changed anything except updating to the new version in the updater and now I get the double speak symptoms of having multiple speech proxies running at once. My phone is the only one connected and I have use as speaker client unchecked. When I disable the plugin everything goes back to normal. Anyone else seeing this?
Latest version is registered as a speech proxy?
Hmm... i wonder than if there is a conflict with that plugin somewhere.
I still haven't been able to get my russound unit setup for speech yet and start to use BLSpeech, so won't be able to help there. Sorry .
FWIW, it's not happening for me and I am using the HSTouch Speech proxy only right now.
Originally posted by S-F View PostI haven't changed anything except updating to the new version in the updater and now I get the double speak symptoms of having multiple speech proxies running at once. My phone is the only one connected and I have use as speaker client unchecked. When I disable the plugin everything goes back to normal. Anyone else seeing this?
Check if you have DisableHS3Speech=1 in tl_tasker_settings.ini under [settings] if not add the line and test again.Please excuse any spelling and grammatical errors I may make.
Tasker Plugin / Speech Droid
Tonlof | Sweden
Originally posted by tonlof View PostStrange, nothing is change between the update more than licence type.
Yep. That was it. It was set to 0 for some reason. Thanks!Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Well, I'm on the latest version and every time I restart HS3 the speech proxy box is checked again. So I have to go in and manually uncheck it. Then every thing behaves normally until another restart. After unchecking it speech proxy is set to 0 in tl_tasker_settings.ini.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by S-F View PostWell, I'm on the latest version and every time I restart HS3 the speech proxy box is checked again. So I have to go in and manually uncheck it. Then every thing behaves normally until another restart. After unchecking it speech proxy is set to 0 in tl_tasker_settings.ini.Please excuse any spelling and grammatical errors I may make.
Tonlof | Sweden
Originally posted by S-F View PostYep. That seems to have sorted it. Thanks again!Please excuse any spelling and grammatical errors I may make.
Tonlof | Sweden
