I spent almost 2 days trying to get the release plugin that is in the updater to work, but I had major problems with it! Uninstalled everything and loaded Beta 1.0.0.142 and it seems to work ALMOST as it should. In the Device Management page, when I hit the blink or flash buttons, they only work about 70-80% of the time. Sometimes I have to hit the button multiple times to activate an output. Flash seems to be the most buggy and it only fires a programmed output occasionally. For the flash function, I have created a work-around event where if an input on board 1 is activated by an event, I turn ON a pin driving a buffered relay on board two, then I add a wait event of .2 seconds and then an OFF statement. This, at least, works every time.
Any ideas?
Running HS3.0.0.368 on Windows 10.0.15063
Any ideas?
