Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HS-MS100+ Motion Sensor
HS-MS100+ Motion Sensor Forum for HomeSeer HS-MS100+ Motion Sensor
Old February 2nd, 2018, 08:52 PM
jordonmusser jordonmusser is offline
Not sensing
Included no problem but it doesnt seem to work. It shows motion sensed when I first included it but not since that point in time...
Current Date/Time: 2/2/2018 6:50:10 PM
HomeSeer Version: HS3 Standard Edition 3.0.0.399
Operating System: Microsoft Windows 10 Home - Work Station
System Uptime: 1 Day 23 Hours 22 Minutes 13 Seconds
IP Address: 192.168.1.33
Number of Devices: 175
Number of Events: 9
Available Threads: 200
HSTouch Enabled: True
Event Threads: 0
Event Trigger Eval Queue: 0
Event Trigger Priority Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Anti Virus Installed: Windows Defender
Enabled Plug-Ins
3.0.0.25: ImperiHome
3.1.0.0: LimitlessLED
30.0.0.36: RFXCOM
3.1.0.22: Sonos
3.0.1.130: Z-Wave
Old February 3rd, 2018, 03:14 AM
NetworkGuy NetworkGuy is offline
It should have 3 devices rather than the five you got. I had to grab the available beta version of the Z-Wave plug-in to get mine to include correctly. Give that a try and you should have better luck...
Old February 3rd, 2018, 11:52 AM
I tried the Beta, still no dice although I did only get 3. It shows motion from when I first installed it but none since.
Old February 3rd, 2018, 11:55 AM
Rupp's Avatar
Rupp Rupp is offline
You should remove this device from HS3, then update your Z-Wave plugin to the latest release, then re-add the device and it should work.
-Rupp
Old February 3rd, 2018, 12:09 PM
That is exactly what I did but I will try it again
Old March 22nd, 2018, 02:57 AM
tsylandera tsylandera is offline
Viewer
Receiving Tamper Event but not motion events
I'm seeing very similar behavior. The only motion event I receive is when the device is Included. And then the only events I receive are tamper events. Wasn't expecting to have to shake my lights on...
Old May 21st, 2018, 10:22 PM
vlad vlad is offline
Viewer
same problem, using HomeAssistant. Any solution?
Ecobee motion sensing twidfeki Ecobee (3P) 5 May 20th, 2017 06:44 AM
Signal sensing question millrl Bitwise Controls BC4 1 April 3rd, 2010 09:13 AM
Trouble with HSM100 sensing on HS 2.4 GPrade Motion Sensor Plug-In 0 December 7th, 2009 11:46 AM
Signal Sensing BitWise_Mark Bitwise Controls BC4 4 December 11th, 2008 12:55 PM
Motion Sensing Script steve6341 Script & Plug-In Library Discussion 1 September 16th, 2003 11:24 PM
