INSTALLATION / CONFIGURATION
System Requirements:
This plugin is for HS3 or HS3PRO. It works only on Windows.
Prerequisites:
You need to download and install
1. the Microsoft Speech Platform - Runtime (version 11) You need the x86 version even on a 64bits machine.
2. and at least one compatible Runtime Language (e.g. MSSpeech_SR_en-US_TELE.msi)
Note: if you already have the kinect plug-in installed, you should already have everything you need.
Plugin Installation:
Download and install from the updater ("User Interfaces" section) or download package from the Beta Testing thread and follow instructions to install.
Plugin Configuration
- Start the plugin from the "PLUG-INS > Manage" page wait a few seconds for the plugin to initialize
- go to the config page "PLUG-INS > Alexa > Config" and click the "Authorize" button
then you should see a page like this:
- Click Okay, then go back to the plugin config page and click the "Done" button. If everything is ok, the config page should be refreshed, and you should see something like in the screenshot below.
- Click the "Test" button, you should hear a quick sound that means Alexa has started listening. Say something like "Tell me a joke" or "What time is it?", after another sound that means Alexa has stopped listening, she should answer you.
In the Audio settings section you can choose the microphone and speakers you want to use. Any microphone and speakers compatible with Windows should work with the plugin (including the Microsoft Kinect)
Alexa Configuration
From: http://alexa.amazon.com/#settings, click on your device and set your zip code. Modify other settings according to your tastes.
Prerequisites:
Alexa Configuration
