Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > HiTec Homes Plug-Ins > VWS
VWS Discussion area for the VWS (Virtual Weather Station) plug-in by Hi-Tec Home
Old June 20th, 2015, 05:07 PM
pete@malibubeach.com pete@malibubeach.com is offline
Seer Master
Excessive CPU usage
I have been chasing a problem with excessive CPU usage on HS3 --- this has led to some horrible reaction time on events. After a lot of trouble shooting (I was initially looking at my events), I started shutting down plug-ins. While HSPI_VWS itself doesn't use much CPU (0-5%), when I shut down the plugin, my HS3 CPU usage goes down from a range of 60-80% down to about 10-15%. Something in the plugin is causing excessive HS3 CPU, which is causing my event processing to be delayed in some cases by up to 30 seconds, compared to triggering the same events with the VWS plugin disabled.
Any thoughts? I have it configured to poll the csv file every 5 seconds and the dbase file every 120 seconds (thought changing those numbers seems to have little or no effect on the CPU utilization).
Old July 2nd, 2015, 09:33 PM
Seer Master
I was hoping you'd have some thoughts on this!
Old July 4th, 2015, 09:28 AM
lpitman's Avatar
lpitman lpitman is offline
Seer Master
Not sure whats happening, I will check the cpu here, but didn't notice any degradation. Let do some testing and and get back to you. I had a new version ready for uploader, but will hold off until I figure this out.
-Larry
A member of "The HA Pioneer Group", MyWebSite
WHS 2011 Server - SageTV, HS 2.2.29 with 9TB Shared Hard Disk.
Plugins:
Ocelot, MitsubishiTV, DenonAVR, DirecTV, DVDMovies, HAI-Thermostat, HAI, Hauppauge, lrpSpeak, MediaPlayer, Rain8Net, Sprinklers, UIRT, VWS.
Hardware:
Intel 3.0Ghz CPU with 12Gb. Ram and 2Tb SATA HD. Davis Inst. VantagePro II, AB8SS, Rain8Net, RC80 Thermostat, OmniProII, Ocelot, X10, UPB, HD-200 Extenders.
Old July 4th, 2015, 09:29 AM
lpitman's Avatar
Seer Master
Not sure whats happening, I will check the cpu here, but didn't notice any degradation. Let me do some testing and and get back to you. I had a new version ready for uploader, but will hold off until I figure this out.
Old July 4th, 2015, 08:46 PM
Seer Master
Hi Larry,
I just downloaded whatever is on the updater (noticed I had an older version) and I think the CPU issue has gone away. My CPU is still all over the map, but it spends a lot of its time near zero (which was not happening before), and I suspect the spikes are not VWS any more. I have too many plug-ins running right now to easily isolate the CPU user, but I saw no noticeable change when I enabled VWS. Don't know if you changed something in 3.0.0.19, or if something also changed on my system, but for now all looks good.
(Guess I'll go pay for it while it is still working well and my 30 days hasn't expired )
Pete
Old February 17th, 2016, 12:04 PM
vince954 vince954 is offline
Seer Plus
i am having a similar issue with the latest verison 3.0.0.21 where without the plugin my cpu load is in the 10% range, with it running I go to above 80% steady. I tried changing the interval for csv and database loads all the way to 45 seconds with no improvement. any ideas?
Old February 26th, 2016, 12:24 PM
lpitman's Avatar
Seer Master
Quote:
I am going to try a couple of experiments this weekend. The only thing I can think of might be the DotNet version that it is compiled in. I have noticed other issues when using some of the latest DotNet versions from MS.
Old March 21st, 2016, 09:22 PM
Seer Plus
any news?
did you find the cause? would love to have this plugin enabled.
Old April 13th, 2016, 09:10 AM
Seer Plus
even with the latest version using this plugin takes my cup usage to 90% the plugin is set to update every 30 seconds which should not be excesive, any ideas?
Old July 19th, 2016, 09:57 AM
RenderCAD's Avatar
RenderCAD RenderCAD is offline
Seer Plus
wrong temperature rate values
Hello Larry,
After two years that I use the plugin WVS in my home automation system I believe that is the most important plugin to manage the confort in every smart house. I resolved the issue about excessive CPU usage on HS3 working only with file CSV and not with dbbase . In this way the system doesn't work with all 105 values but only with 36. The CPU is in the range 70-80%.
However the issue that never been resolved is the reading about some values like : Channel 1 Temp Rate , Channel 2 Temp Rate, Channel 3 Temp Rate. In attached you can see that these values are equal but if you look in the VWS there is not so. Pheraps the firt can be rigth but the others two no. From last month I use one script taken in the forum with which is possible easy compare two value inside interface events and sometimes I should need to use these "temp rate values" but now these values are errate
can you look it please
Massimo-RenderCAD
_________________________________________________________
HomeSeer Version: HS3 Pro Edition 3.0.0.280
Operating System: Microsoft Windows 7 Professional - Work Station
Number of Devices: 370, Number of Events: 165, Available Threads: 200
Enabled Plug-Ins
3.0.0.29: ADIO-100
1.0.0.85: Arduino Plugin
0.0.0.39: Current Cost 3P
0.0.0.3: Device Comparison 3P
3.0.0.75: HSTouch Server
3.0.0.11: NetCAM
1.0.0.3: Restart
3.0.0.21: VWS
3.0.1.83: Z-Wave
Old July 27th, 2016, 08:14 AM
lpitman's Avatar
Seer Master
Checking...
Old August 1st, 2016, 02:29 PM
RenderCAD's Avatar
Seer Plus
Hi Larry.
If this can be usefull, my software VWS is V15.00 p05 Internet Edition. One other information but I dont't kwnow if this is important about the incorrect values downloaded in the HS3PRO ( post 10): my weather station is OREGON WMRS200
Massimo RenderCAD
HomeSeer Version: HS3 Pro Edition 3.0.0.293 - Operating System: Microsoft Windows 7 Professional - Work Station Number of Devices: 301, Number of Events: 167, Available Threads: 200
Enabled Plug-Ins
3.0.0.29: ADIO-100
3.0.14.0: BLMediaPlayer
2.0.5.0: BLVolume
3.0.0.35: Current Cost
3.0.0.27: EasyTrigger
3.0.0.11: NetCAM
1.0.0.3: Restart
3.0.0.21: VWS
3.0.1.83: Z-Wave
Old September 12th, 2016, 05:37 PM
RenderCAD's Avatar
Seer Plus
Quote:
Originally Posted by lpitman View Post
Checking...
Hello Larry
Did you find the solution about incorrect values ? (Channel 1 Temp Rate , Channel 2 Temp Rate, Channel 3 Temp Rate)
thanks
Massimo - RenderCAD
Old April 10th, 2017, 11:38 AM
RenderCAD's Avatar
Seer Plus
VWS-temp rate
hello
The problem that I reported long time ago, has been resolved? How I said in the past, the possibility to analize some conditions about termic confort through the use of the temp rate values is very important
Massimo RenderCAD
HomeSeer Version: HS3 Pro Edition 3.0.0.318
System Uptime: 0 Days 1 Hour 29 Minutes 37 Seconds Number of Devices: 353 Number of Events: 206 Available Threads: 200
Enabled Plug-Ins
3.0.0.29: ADIO-100
2.0.3.0: BLDatabase
2.0.5.0: BLVolume
3.0.0.21: Buienradar
0.0.0.40: Current Cost 3P
1.1.2.0: Device History
3.0.0.32: EasyTrigger
3.0.0.11: NetCAM
3.0.1.84: PHLocation
1.0.0.5: Restart
3.0.0.21: VWS
3.0.1.93: Z-Wave
HTML code is On
Excessive beep delay on OGM email68 HomeSeer Phone 6 December 7th, 2011 04:49 PM
Daily water usage and hourly water usage vic1743 RFXCOM Plug-In (3P) 2 October 20th, 2010 03:08 PM
Excessive Battery usage mbreeden HSM100™ Multi-Sensor 19 January 25th, 2010 06:45 PM
HSM100 Excessive Battery Usage Mark42 HSM100™ Multi-Sensor 5 October 21st, 2009 08:36 PM
