Hi all,
I've had a Texecom Veritas R8 panel for years which came installed in my house. It's been unreliable for ages and reliably interfacing it with my HS3 system is more or less impossible using PLC-BUS scene modules. It doesn't have any comms outputs.
The system has a remote external (hardwired) SAB sounder, a couple of door contacts and 3 PIR sensors - so not big at all.
I've decided I want to replace the system with something that can interface HS3 using a plugin. I want to be able to trigger events from sensors being tripped. Also the other important factor is that it is impossible to hard wire a connection between where the panel is and the HS3 PC, so I need a panel that has WIFI capability to sit on the network and be able to communicate with HS.
Ideally I could do with a system that is available in the UK to avoid import tax and voltage differences. The sensors are all ok, however the SAB could use replacing. I'm happy to consider wireless systems too - which would give me the option of expanding the system.
If anyone has any recommendations I would be EXTREMELY grateful.
Best wishes,
Jay
Does anyone have any suggestions for a system
Best wishes,
Jay
