I have a 16 port X10 relay switch that I have switching speakers off and on. It works flawlessly with a maxi controller. For some reason I can not do it through homeseer using the TI103. Here is what my log is when I try and turn one of the relays on:
2/24/2005 9:31:07 PM~!~Device control from menu~!~B9 On
2/24/2005 9:31:07 PM~!~Debug TI103~!~InParsed(0): $<2800! B0916#
2/24/2005 9:31:07 PM~!~Debug TI103~!~ProcessX10: $<2800! B0916#
2/24/2005 9:31:07 PM~!~Debug TI103~!~InParsed(0): $<2800!B09 BONF5#
2/24/2005 9:31:08 PM~!~Debug TI103~!~ProcessX10: $<2800!B09 BONF5#
2/24/2005 9:31:08 PM~!~Debug TI103~!~InParsed(0): $<2800!BON2A#
2/24/2005 9:31:08 PM~!~Debug TI103~!~ProcessX10: $<2800!BON2A#
I know I had tested this (probably not the same plugins, was a week ago) and it was working through homeseer. One thing I did add into the mix since then is a Crown Amplifier. My basement isn't completely finished so I do have a lot of this stuff on power strips. Like I said the MAXI Controller is working fine, do you think the signal from the TI103 is interfering with something. I don't even get the light to flash on the 2 way power line interface. Although I did unplug the amp all together and it still not work so I doubt thats the problem?
Thanks for any help!
-Nathan
-Nathan
