Tested the Zee today with a CM11A connected via a USB to serial device. Works fine. Validated its functions turning on A1 and turning off A1.
Rebooting though to see if the above log errors go away. I have updated the Zee to most current version of HS3; IE: V.38?
Wondering now if the update didn't work as planned; something is amiss in homeseerlandia on the Zee.
Only error seen on reboot is:
Geez where the heck would a zero ini file come from anyways? There is none there; wonder if it was meant to be there?
Oct-29 8:22:01 AM Error Exception deserializing a saved status page data item from the database - it will NOT be loaded! Item: ContainerID=, User=
Oct-29 8:21:31 AM Device Control Device: X10 x10 A1 to Off (-1) by/from: CAPI Control Handler
Oct-29 8:21:27 AM Device Control Device: X10 x10 A1 to On (101) by/from: CAPI Control Handler
Oct-29 8:14:47 AM Warning File does not exist: /usr/local/HomeSeer/html/custom.css
Oct-29 8:14:47 AM Warning File does not exist: /usr/local/HomeSeer/html/style.css
Oct-29 8:10:49 AM Error Exception in local_add: Object reference not set to an instance of an object
Oct-29 8:08:58 AM Plug-In Finished initializing plug-in X10
Oct-29 8:08:57 AM Info Initializing CM11A/12U on COM port /dev/ttyUSB0
Oct-29 8:08:57 AM Warning Cannot find requested INI file: /usr/local/HomeSeer/Config/0
Oct-29 8:08:29 AM Startup Start up complete.
Oct-29 8:28:58 AM Info Initializing CM11A/12U on COM port /dev/ttyUSB0
Oct-29 8:28:58 AM Warning Cannot find requested INI file: /usr/local/HomeSeer/Config/0
Oct-29 8:28:58 AM Startup Initializing Plug-Ins
