Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > HiTec Homes Plug-Ins > VWS
VWS Discussion area for the VWS (Virtual Weather Station) plug-in by Hi-Tec Home
Old February 25th, 2014, 02:34 PM
yelloow7t's Avatar
yelloow7t yelloow7t is offline
Missing .png files
I don't have a \html\images\devices\vws directory. I saw a VWS install help file somewhere that said to unzip a file, but never could find the specified file.
Old February 25th, 2014, 04:38 PM
lpitman's Avatar
lpitman lpitman is offline
Un-Install plug-in and install from updater. Correct directories should be created and graphics copied into those directories. I will also double check install while I am investigating the device deletion issue. Which wont be until I get home this evening.
-Larry
A member of "The HA Pioneer Group", MyWebSite
WHS 2011 Server - SageTV, HS 2.2.29 with 9TB Shared Hard Disk.
Plugins:
Ocelot, MitsubishiTV, DenonAVR, DirecTV, DVDMovies, HAI-Thermostat, HAI, Hauppauge, lrpSpeak, MediaPlayer, Rain8Net, Sprinklers, UIRT, VWS.
Hardware:
Intel 3.0Ghz CPU with 12Gb. Ram and 2Tb SATA HD. Davis Inst. VantagePro II, AB8SS, Rain8Net, RC80 Thermostat, OmniProII, Ocelot, X10, UPB, HD-200 Extenders.
Old February 25th, 2014, 07:05 PM
yelloow7t's Avatar
Larry,
I installed initially from the updater late last week. Updater says it is current and I have 26 days left on trial.
Tom
Old February 26th, 2014, 04:30 PM
lpitman's Avatar
Attached is zip file for the html directory. I will check the help file, sounds like it neglected to get updated.
HTML code is On
Missing .dll files ATEngineer HomeTroller-SE 1 December 11th, 2012 11:59 AM
Missing Image Files simonog RFXCOM Plug-In (3P) 3 February 12th, 2009 02:44 AM
Missing Menu Links and Files chazelton HomeSeer Global Cache Plug-in 14 December 2nd, 2008 07:14 PM
new setup, missing files Mike HS2 / HSPRO 15 August 28th, 2005 10:10 AM
Missing include files matssparr Script & Plug-In Library Discussion 1 July 4th, 2002 11:41 AM
