Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > HiTec Homes Plug-Ins > VWS
VWS Discussion area for the VWS (Virtual Weather Station) plug-in by Hi-Tec Home
Old June 6th, 2015, 12:16 PM
Jerry S Jerry S is offline
Repeating HS Log Msg - Data is older than 15 minutes, Check VWS
I am in the process of upgrading from HS2 to HS3, currently running the trial of your VWS plugin. All seems to be working well.
However, I forgot to start VWS after a recent reboot, and started receiving the following error, 18 times per second, every second.
Jun-06 12:11:33 PM
VWS Info Data is older than 15 minutes, Check VWS
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:33 PM
Jun-06 12:11:32 PM
I appreciate being notified when there is a problem with stale data coming from VWS, but is there anything that can be done about this message repeating so often?
Thank you,
Jerry
Old June 10th, 2015, 04:51 PM
lpitman's Avatar
lpitman lpitman is offline
Start up VWS so data can be read. Under normal circumstances the error would never be seen. Then other method would be to change (decrease) the polling frequency in config.
-Larry
A member of "The HA Pioneer Group", MyWebSite
WHS 2011 Server - SageTV, HS 2.2.29 with 9TB Shared Hard Disk.
Plugins:
Ocelot, MitsubishiTV, DenonAVR, DirecTV, DVDMovies, HAI-Thermostat, HAI, Hauppauge, lrpSpeak, MediaPlayer, Rain8Net, Sprinklers, UIRT, VWS.
Hardware:
Intel 3.0Ghz CPU with 12Gb. Ram and 2Tb SATA HD. Davis Inst. VantagePro II, AB8SS, Rain8Net, RC80 Thermostat, OmniProII, Ocelot, X10, UPB, HD-200 Extenders.
Old June 18th, 2015, 11:07 PM
pete@malibubeach.com pete@malibubeach.com is offline
It would be nice if this message only came out once -- it is further reflected in the VWS Data Status device, so the log entry seems extraneous. In my case, I never reset the time ahead to DST, so I get the log message continuously until I remember how to change the settings on the device and update the time to DST.
HTML code is On
Looking for an older than 2.0.0.14 DSC DLL jtsnyderjr HomeSeer DSC Plug-in 0 June 17th, 2012 02:11 PM
Still getting repeating messages jwshome2 Vista Alarm Plug-in (3P) 13 February 22nd, 2012 08:05 PM
X minutes after sunset, Y minutes before sunrise Madcodger HomeSeer General Discussion Area 17 November 29th, 2011 03:33 PM
Repeating Key? fuxuepeng Sage Media Center Control 2 July 22nd, 2011 04:07 PM
minutes before sunrise and minutes after sunset not working? purezerg HS2 / HSPRO 4 January 27th, 2009 05:14 AM
