Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > HiTec Homes Plug-Ins > VWS
VWS Discussion area for the VWS (Virtual Weather Station) plug-in by Hi-Tec Home
Old July 13th, 2015, 08:42 PM
neidichr neidichr is offline
Default HS# Path
Is there a way to change the default VWS start path. My instance of HS3 is C:\Program Files\HS3 not C:\Program Files (86)\HS3. I have the current file paths set, but they don't persist since the VWS plug-in has a path different than my install.
Old July 14th, 2015, 12:42 PM
lpitman's Avatar
lpitman lpitman is offline
Edit the VWS.ini in the config directory.
-Larry
A member of "The HA Pioneer Group", MyWebSite
WHS 2011 Server - SageTV, HS 2.2.29 with 9TB Shared Hard Disk.
Plugins:
Ocelot, MitsubishiTV, DenonAVR, DirecTV, DVDMovies, HAI-Thermostat, HAI, Hauppauge, lrpSpeak, MediaPlayer, Rain8Net, Sprinklers, UIRT, VWS.
Hardware:
Intel 3.0Ghz CPU with 12Gb. Ram and 2Tb SATA HD. Davis Inst. VantagePro II, AB8SS, Rain8Net, RC80 Thermostat, OmniProII, Ocelot, X10, UPB, HD-200 Extenders.
Old July 14th, 2015, 08:38 PM
pete@malibubeach.com pete@malibubeach.com is offline
I have the same problem
the VWS.ini file is fine. But the plug-in is NOT reading it. It is looking for one in another directory (C:\Program Files (86)\HS3). But it updates the one in C:\Program Files\Homeseer HS3. Took me awhile to figure out what was going on---everytime the plug-in restarts, it could not find the csv and dbase files --- I update them and it works (and saves the updates in C:\Program Files\Homeseer HS3). I solved the problem by copying the ini file to the other directory, but that isn't the way it should be!
Old July 17th, 2015, 11:10 AM
lpitman's Avatar
Version 3.0.0.21 fixes this, and was sent to updater.
HTML code is On
Upgrade Path? bhenderson mcsSprinklers 1 July 26th, 2008 11:34 AM
Path not found mbreeden HSTV 10 January 11th, 2005 08:32 PM
Migration path danwhiley Homevision 1 August 26th, 2004 10:46 AM
Migration path danwhiley Homevision 0 January 1st, 1970 12:00 AM
