Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > HiTec Homes Plug-Ins > VWS
VWS Discussion area for the VWS (Virtual Weather Station) plug-in by Hi-Tec Home
Old October 25th, 2015, 09:19 AM
RenderCAD's Avatar
RenderCAD RenderCAD is offline
Seer Plus
HS3 events with devices from VWS
I'm trying to solve this problem
I want to open my windows already controlled through motors with integrated relay Z-Wave to my home automation system when certain conditions occur
for example: from the chart control external and internal temperature is noted that in the hottest time of the day the temperature outside is higher than the indoor temperature of the house, that is the moment in which the automation system should open the windows. My only difficulty is that to write the event because I have not figured out how to compare the internal temperature with the outside.
I can trigger an event when there is a particular value of a sensor and this is easy but how does the home automation system to trigger an event when the outside temperature exceeds the inside?
thank you
Massimo
RenderCAD
_____________________________________
HomeSeer Version: HS3 Pro Edition 3.0.0.208
Operating System: Microsoft Windows 7 Professional - Work Station
Number of Devices: 307 - Number of Events: 110
Enabled Plug-Ins
3.0.0.29: ADIO-100
1.0.0.85: Arduino Plugin
0.0.0.27: Current Cost 3P
3.0.0.35: Current Cost
3.0.0.75: HSTouch Server
3.0.0.11: IFTTT
3.0.0.11: NetCAM
1.0.0.2: Restart
3.0.0.21: VWS
3.0.1.25: Z-Wave
Old March 21st, 2016, 07:40 PM
RenderCAD's Avatar
Seer Plus
Hi Larry,
I haven't solve the iussue yet. I don't know if I didn't describe well the situation in the past post. I'd run the event "open windows" when the OUT temp is greater than the IN temp and the run the event "close windows" when the OUT temp is less than the IN temp. Is possible run the event without use of the particular script ? Thanks
Massimo-RenderCAD
___________
Current Date/Time: 22/03/2016 00:36:30
HomeSeer Version: HS3 Pro Edition 3.0.0.258
Number of Devices: 363 Number of Events: 149
Enabled Plug-Ins
3.0.0.29: ADIO-100
3.0.13.0: BLMediaPlayer
3.0.0.11: NetCAM
1.0.0.3: Restart
3.0.0.21: Sonos
3.0.0.21: VWS
3.0.1.44: Z-Wave
HTML code is On
Controlling x10 devices or events from z-wave devices maverick HomeSeer Z-Wave Plug-in 6 November 16th, 2009 01:30 PM
No Devices or Events weathrman1 HS2 / HSPRO 4 February 19th, 2008 12:03 PM
Devices in events nightwalker HS2 / HSPRO 2 July 14th, 2007 06:45 PM
NOW I've done it - all devices/events,etc. gone! ajackson123 HomeSeer General Discussion Area 4 August 13th, 2005 02:04 PM
devices and events? happnatious1 SeerAMP (3P) 3 February 17th, 2005 10:51 AM
