Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > HiTec Homes Plug-Ins > VWS
VWS Discussion area for the VWS (Virtual Weather Station) plug-in by Hi-Tec Home
Old January 11th, 2017, 01:01 PM
buvens buvens is offline
Not Picking up Daily Rain accurately
My Ambient VWS station shows 0 for daily rain but the VWS pluggin shows ".71".
The other day when we had rain the pluggin always stayed at ".71" but the daily rain on the the PC with the VWS station screen indicated the correct amount.
Any idea where I might look to correct this?
Thanks..
Remember to have FUN....Sonny
HS#Pro on HP with SSD, 4 channel Modulator, Davis weather station, X10, DS-10's, Zwave with 2-Z-Nets Intermatic, Schlage Link Locks and Trane Zwave thermostat, Home Server, W800, RFXcom, OS temp sensors, Iphones, Genset, bunches of relays, wires etc
Lots of fun.
Old August 18th, 2017, 10:19 AM
RenderCAD's Avatar
RenderCAD RenderCAD is offline
Seer Plus
Hello
I use VWS plugin from when I began to use the software homeseer but I don't know if I can help you. I use V.15.00 p05 (WVS) and I import from VWS only data.csv and non dbase.csv because my cpu isn't so much quick, however that issues that you have I haven't about device "daily rain" but I have the problems in the "Temp rate 2" and "Temp rate 3" where the plugin write the same value of the "Temp rate 1" . The problems never end......
Massimo-RenderCAD
HomeSeer Version: HS3 Pro Edition 3.0.0.318 Operating System: Microsoft Windows 7 Professional - Work Station
Number of Devices: 381 Number of Events: 210
Enabled Plug-Ins
3.0.0.29: ADIO-100
1.0.0.85: Arduino Plugin
2.0.3.0: BLDatabase
3.0.14.0: BLMediaPlayer
2.0.5.0: BLVolume
0.0.0.42: Current Cost 3P
0.0.0.3: Device Comparison 3P
1.2.0.0: Device History
3.0.0.33: EasyTrigger
5.0.0.58: Global Cache Pro
3.0.0.75: HSTouch Server
3.0.0.14: NetCAM
3.0.1.90: PHLocation
1.0.0.5: Restart
3.0.0.21: VWS
3.0.1.130: Z-Wave
HTML code is On
Rain Last Hour and Rain Today no longer populating lveatch WeatherXML 8 January 9th, 2016 12:17 PM
EZFlora HS3 - no rain sensor but HS3 rain sensor device toggles on and off? nfrobertson EZFlora Insteon Irrigation Controller Plug-in 3 June 14th, 2014 03:32 PM
RFX not picking up DS10a afmiller RFXCOM Plug-In (3P) 1 December 15th, 2011 09:39 PM
plug-in accurately reporting available links? bobwondernut Insteon Plug-in (Mark Sandler) 3 May 20th, 2008 04:42 PM
