Echo Skill Device Detection
    Are there any known issues with the UK skill that is preventing it detecting devices.
    Mine does not seem to detect any of my LightwaveRF devices, even though they arer setup and working fine in Homeseer
    Do you have the Voice command ticked under the device configuration?
    Jon
      Do the devices have the Voice command box checked in the configuration area of there settings?
      Wade
      "I know nothing... nothing!"
        Yes, I have turned voice command on for both the LightwaveRF devices and also the RFXCOM device
          I should note.....I have tried it with and without it turned on
          Also tried the latest stable firmware and also the new beta firmware
            You need them checked when you do your device discovery.
            Do you have any devices that were discovered?
            Wade
              I had the voice command ticked during the discovery, but still didnt work.
              2 of my Z Wave devices have been found (Aeon Labs), but None of the LightwaveRF devices are being detected
                Same issue i think - Fixed it
                Check the "control use" drop downs under Status graphics, none of these are set using RFCom and i had the same problem so it may be the same issue.
                Cheers
                Matt
                  Originally posted by 10monkeys View Post
                  Cheers
                  Matt
                  Ha - Ignore that (it did work though), we had the same conversation elsewhere in the forum
                  Matt
