I've got the plugin running on the server, and trying to connect from two different android devices, both inside and outside the home network. It seems to connect and initialize, but nothing shows up. The server says no clients connected, the client shows nothing in the app (I have various things checked to show up). I've tried restarting Homeseer (3), no luck. Any suggestions?
EDIT: as a test, I disabled the plugin. I tried to connect, the android app still 'connects'. However, if I leave it enabled, and enter incorrect IP info, it can't connect. I have also tried disabling all firewalls, and changed port numbers, no luck. Not sure what I'm doing wrong here
EDIT 2: I installed the trial on another machine, different IP and port, and BLcontrol is the only plugin installed as well. Same issue
