Rain8net & Relay8net
    Hello,
    Just got my Rain8net and Relay8net modules, installed the RainRelay8 plugin in HS. Rain8net is working fine. Now trying to connect the relay8net to the Rain8net so i can use both modules on the same com port using the same plugin. Found the cable here "Relay8net to Rain8net Adapter Set". Can anyone advice on how i can make my own cable? i already got a DB9 - RJ45 connector.
    I'm also wondering if i go ahead and install the Rain8 on top of the current RainRelay8 plugin, configure the Rain8net to use the Rain8 plugin and the Relay8net to use RainRelay8 plugin will this approach work? Does this also mean i have to purchase both plugins?
    Please Advice,
    solved
    Thanks to Warren's support at WGL, I made my own Y serial splitter. Both Rain8net and Relay8net are now working on the same com port using the RainRelay8 plugin..
