I understand .... PlcBus scene programming is really weird... I could never understand why there is no PlcBus command to add a module to a scene with a specific dim level/ramp rate ... Adding "On devices" is fine if you have a few modules, but if you have 70, it must be a nightmare....
Super slow PLCBUS scene change (HS3 only)
Originally posted by stipus View PostI understand .... PlcBus scene programming is really weird... I could never understand why there is no PlcBus command to add a module to a scene with a specific dim level/ramp rate ... Adding "On devices" is fine if you have a few modules, but if you have 70, it must be a nightmare....
The programming part can be kind of iffy, but at least it should be a one-time thing. I'm quite amazed at the reliability of the system though, I didn't think it would scale this well to 70+.HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
Google Search for HomeSeer Forum
Originally posted by stipus View PostI have about 30 PlcBus modules, and as long as all modules are correctly wired (live on live, neutral on neutral) I don't remember getting any miss. It has been perfectly reliable for years.
Btw I have some (very seldom used) modules that don't respond to status checks (polls, etc) but can be controlled and programmed with scenes. Which cable is loose/disconnected in that case?HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
If you have any module in your house plugged with reversed wires, then other modules can randomly not respond (no ack responses, problem with polling)...
The secret for 100% reliability is to check all modules and PlcBus computer interface for correct wiring or plugging. Live MUST go on live, especially for plug-in modules that can too easily be plugged the wrong way (at least with french plugs).
I also had one faulty module, that could not reply to any command (it did not respond to poll, ack requests, signal strength, noise level...) but could receive requests (it did react to ON/OFF...). This module was replaced by the vendor, and I didn't have any other problem since then.--
stipus
Originally posted by stipus View PostIf you have any module in your house plugged with reversed wires, then other modules can randomly not respond (no ack responses, problem with polling)...
I notice that when I poll the house codes, there are some modules missing from the list that I know should exist and connected to my powerline. So I will start by checking the wiring of those modulesfirst. I know that 100% of the modules in my house respond to on/off commands, but once I get into the programming part (polling, scene creation, checking for noise and signal strength) there are some modules that don't reply.HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
In my experience:
- With plug-in modules, you may also want to check the live position in the wall socket. Sometimes it can happen that the wires are not wired correctly in the socket. Then you think the plug-in module is connected the right way when it's not.
- I understand that you want to check the "not responding" modules first... but sometimes it can be another module with reversed wiring that "blocks" other modules...--
stipus
- I understand that you want to check the "not responding" modules first... but sometimes it can be another module with reversed wiring that "blocks" other modules...HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
Originally posted by stipus View PostDid you get any other problem with the latest version ? Do you think I can send it to the HomeSeer updater ?
Thanks,HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
@stipus: I tested creating and deleting new scenes with no problems. But found out 'Remove currently 'On' devices' doesn't work properly. Example:
1. Create scene B1 that turns on A1, A2, A3, A4. Success.
2. We want to remove A3 and A4... so turn A1, A2 OFF and leave A3, A4 ON.
3. Run 'Remove currently 'On' devices' on scene B1.
4. ALL OF THE LIGHTS IN THE SCENE WILL TURN ON, then A3 and A4 are removed from the list. The 'success checkmark' icon shows up in the status column.
5. Then after that, none of the lights in scene B1 (A1, A2 too) respond to ON/OFF any more. But the text on the scene looks correct (B1 = A1 on, A2 on)
So 'Remove currently On devices' acts like 'remove ALL devices in this scene' to me. Maybe on step #4, it mistakenly fires B1 ON, then issues the device removal command, effectively removing all devices in that scene.Last edited by LeoS; May 19, 2015, 09:43 AM.HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
Stipus, is the problem description above clear enough? I've just edited it a little more... I was writing it with a bad headache I guessHW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
Originally posted by stipus View PostCan you set the plugin debug mode 'on', try again to remove some modules from a scene, and post the log.
Regards,HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
ps: before this test, I already have scene M3 that controls A1 and A2. It shows up in the log and its status updated in some calls (to sync the status, I assume, since it overlaps with M4).
Code:May-20 11:34:34 AM PLCBUS Debug PostBackProc[] Page=[Configuration] May-20 11:34:33 AM PLCBUS Debug GetPagePlugin[] Page=[Configuration] May-20 11:34:26 AM PLCBUS Debug Rcvd Ack: (138) M4 Off Data1:0 Data2:0 Tx:False AckReq:True Ack:True IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:34:26 AM PLCBUS Debug Sent: (138) M4 Off Data1:0 Data2:0 Tx:True AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:True PlcBusOK:True May-20 11:34:26 AM PLCBUS Debug Sending: (138) M4 Off Data1:0 Data2:0 Tx:False AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:34:24 AM PLCBUS Device Device [138-M4] status set to [Off] May-20 11:34:24 AM PLCBUS Debug Sending: (138) M4 Off Data1:0 Data2:0 Tx:False AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:34:24 AM PLCBUS Device Device [138-M4] status set to [Off] May-20 11:34:24 AM PLCBUS Device Device [138-M3] status set to [Off] May-20 11:34:24 AM PLCBUS Device Device [138-A1] status set to [Off] May-20 11:34:24 AM PLCBUS Device Device [138-M4] status set to [Off] May-20 11:34:24 AM PLCBUS Device Device [138-M3] status set to [Off] May-20 11:34:24 AM PLCBUS Device Device [138-A2] status set to [Off] May-20 11:34:24 AM PLCBUS Debug SetIO[] name=[Scene : Test] address=[138-M4] type=[PlcBus Scene] controlValue=[0] May-20 11:34:24 AM Device Control Device: System zzINACTIVE Scene : Test to Off (0) by/from: CAPI Control Handler May-20 11:34:23 AM PLCBUS Debug Rcvd Ack: (138) M4 On Data1:100 Data2:0 Tx:False AckReq:True Ack:True IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:34:23 AM PLCBUS Debug Sent: (138) M4 On Data1:100 Data2:0 Tx:True AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:True PlcBusOK:True May-20 11:34:22 AM PLCBUS Device Device [138-M4] status set to [On] May-20 11:34:22 AM PLCBUS Debug Sending: (138) M4 On Data1:0 Data2:0 Tx:False AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:34:22 AM PLCBUS Device Device [138-A1] status set to [On] May-20 11:34:22 AM PLCBUS Device Device [138-A2] status set to [On] May-20 11:34:22 AM PLCBUS Debug SetIO[] name=[Scene : Test] address=[138-M4] type=[PlcBus Scene] controlValue=[101] May-20 11:34:22 AM Device Control Device: System zzINACTIVE Scene : Test to On (101) by/from: CAPI Control Handler May-20 11:34:21 AM PLCBUS Debug Rcvd Ack: (138) M4 Off Data1:0 Data2:0 Tx:False AckReq:True Ack:True IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:34:21 AM PLCBUS Debug Sent: (138) M4 Off Data1:0 Data2:0 Tx:True AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:True PlcBusOK:True May-20 11:34:21 AM PLCBUS Device Device [138-M4] status set to [Off] May-20 11:34:21 AM PLCBUS Debug Sending: (138) M4 Off Data1:0 Data2:0 Tx:False AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:34:21 AM PLCBUS Device Device [138-M4] status set to [Off] May-20 11:34:21 AM PLCBUS Device Device [138-M3] status set to [Off] May-20 11:34:21 AM PLCBUS Device Device [138-A1] status set to [Off] May-20 11:34:21 AM PLCBUS Device Device [138-M4] status set to [Off] May-20 11:34:21 AM PLCBUS Device Device [138-M3] status set to [Off] May-20 11:34:21 AM PLCBUS Device Device [138-A2] status set to [Off] May-20 11:34:21 AM PLCBUS Debug SetIO[] name=[Scene : Test] address=[138-M4] type=[PlcBus Scene] controlValue=[0] May-20 11:34:21 AM Device Control Device: System zzINACTIVE Scene : Test to Off (0) by/from: CAPI Control Handler May-20 11:34:19 AM PLCBUS Debug Rcvd Ack: (138) M4 On Data1:100 Data2:0 Tx:False AckReq:True Ack:True IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:34:19 AM PLCBUS Debug Sent: (138) M4 On Data1:100 Data2:0 Tx:True AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:True PlcBusOK:True May-20 11:34:19 AM PLCBUS Device Device [138-M4] status set to [On] May-20 11:34:19 AM PLCBUS Debug Sending: (138) M4 On Data1:0 Data2:0 Tx:False AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:34:19 AM PLCBUS Device Device [138-A1] status set to [On] May-20 11:34:19 AM PLCBUS Device Device [138-A2] status set to [On] May-20 11:34:19 AM PLCBUS Debug SetIO[] name=[Scene : Test] address=[138-M4] type=[PlcBus Scene] controlValue=[101] May-20 11:34:19 AM Device Control Device: System zzINACTIVE Scene : Test to On (101) by/from: CAPI Control Handler May-20 11:34:17 AM PLCBUS Debug Rcvd Ack: (138) M4 Off Data1:0 Data2:0 Tx:False AckReq:True Ack:True IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:34:17 AM PLCBUS Debug Sent: (138) M4 Off Data1:0 Data2:0 Tx:True AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:True PlcBusOK:True May-20 11:34:16 AM PLCBUS Device Device [138-M4] status set to [Off] May-20 11:34:16 AM PLCBUS Debug Sending: (138) M4 Off Data1:0 Data2:0 Tx:False AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:34:16 AM PLCBUS Debug SetIO[] name=[Scene : Test] address=[138-M4] type=[PlcBus Scene] controlValue=[0] May-20 11:34:16 AM Device Control Device: System zzINACTIVE Scene : Test to Off (0) by/from: CAPI Control Handler May-20 11:34:11 AM PLCBUS Debug Sent: (138) M4 SceneAddressErase Data1:0 Data2:0 Tx:True AckReq:False Ack:False IDreq:False Id:False 3PhReq:True RiscOK:True PlcBusOK:True May-20 11:34:10 AM PLCBUS Debug Sending: (138) M4 SceneAddressErase Data1:0 Data2:0 Tx:False AckReq:False Ack:False IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False [B]May-20 11:34:10 AM PLCBUS Debug Scene [138-M4] - Removing ON device=[138-A3] May-20 11:34:10 AM PLCBUS Debug Scene [138-M4] - Removing ON device=[138-A4][/B] May-20 11:34:09 AM PLCBUS Debug SetIO[] name=[Scene : Test] address=[138-M4] type=[PlcBus Scene] controlValue=[502] May-20 11:34:09 AM Device Control Device: System zzINACTIVE Scene : Test to Remove currently 'On' devices (502) by/from: CAPI Control Handler May-20 11:34:01 AM PLCBUS Device Device [138-M4] status set to [Off] May-20 11:34:01 AM PLCBUS Device Device [138-M3] status set to [Off] May-20 11:34:01 AM PLCBUS Device Device [138-A2] status set to [Off] May-20 11:34:01 AM PLCBUS Debug Rcvd Ack: (138) A2 Off Data1:0 Data2:0 Tx:False AckReq:True Ack:True IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:34:01 AM PLCBUS Debug Sent: (138) A2 Off Data1:0 Data2:0 Tx:True AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:True PlcBusOK:True May-20 11:34:01 AM PLCBUS Debug Sending: (138) A2 Off Data1:0 Data2:0 Tx:False AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:33:59 AM PLCBUS Debug Sending: (138) A2 Off Data1:0 Data2:0 Tx:False AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:33:59 AM PLCBUS Debug SetIO[] name=[Main light] address=[138-A2] type=[PlcBus Appliance] controlValue=[0] May-20 11:33:59 AM Device Control Device: 2 Master Bedroom Main light to Off (0) by/from: CAPI Control Handler May-20 11:33:58 AM PLCBUS Device Device [138-M4] status set to [Off] May-20 11:33:58 AM PLCBUS Device Device [138-M3] status set to [Off] May-20 11:33:58 AM PLCBUS Device Device [138-A1] status set to [Off] May-20 11:33:57 AM PLCBUS Debug SetIO[] name=[TV Light] address=[138-A1] type=[PlcBus Appliance] controlValue=[0] May-20 11:33:57 AM Device Control Device: 2 Master Bedroom TV Light to Off (0) by/from: CAPI Control Handler May-20 11:33:56 AM PLCBUS Debug Received: (138) A1 ReportOnlyOnIdPulse3Phase Data1:0 Data2:15 Tx:False AckReq:False Ack:False IDreq:False Id:False 3PhReq:False RiscOK:True PlcBusOK:True May-20 11:33:55 AM PLCBUS Debug Sent: (138) A1 GetOnlyOnIdPulse Data1:0 Data2:0 Tx:True AckReq:False Ack:False IDreq:True Id:False 3PhReq:True RiscOK:True PlcBusOK:True May-20 11:33:54 AM PLCBUS Debug Sending: (138) A1 GetOnlyOnIdPulse Data1:0 Data2:0 Tx:False AckReq:False Ack:False IDreq:True Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:33:50 AM PLCBUS Debug Rcvd Ack: (138) M4 On Data1:100 Data2:0 Tx:False AckReq:True Ack:True IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:33:50 AM PLCBUS Debug Sent: (138) M4 On Data1:100 Data2:0 Tx:True AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:True PlcBusOK:True May-20 11:33:49 AM PLCBUS Device Device [138-M4] status set to [On] May-20 11:33:49 AM PLCBUS Debug Sending: (138) M4 On Data1:0 Data2:0 Tx:False AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:33:49 AM PLCBUS Device Device [138-A3] status set to [On] May-20 11:33:49 AM PLCBUS Device Device [138-A4] status set to [On] May-20 11:33:49 AM PLCBUS Device Device [138-A1] status set to [On] May-20 11:33:49 AM PLCBUS Device Device [138-A2] status set to [On] May-20 11:33:49 AM PLCBUS Debug SetIO[] name=[Scene : Test] address=[138-M4] type=[PlcBus Scene] controlValue=[101] May-20 11:33:49 AM Device Control Device: System zzINACTIVE Scene : Test to On (101) by/from: CAPI Control Handler May-20 11:33:48 AM PLCBUS Debug Rcvd Ack: (138) M4 Off Data1:0 Data2:0 Tx:False AckReq:True Ack:True IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:33:48 AM PLCBUS Debug Sent: (138) M4 Off Data1:0 Data2:0 Tx:True AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:True PlcBusOK:True May-20 11:33:47 AM PLCBUS Device Device [138-M4] status set to [Off] May-20 11:33:47 AM PLCBUS Debug Sending: (138) M4 Off Data1:0 Data2:0 Tx:False AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:33:47 AM PLCBUS Device Device [138-M4] status set to [Off] May-20 11:33:47 AM PLCBUS Device Device [138-A3] status set to [Off] May-20 11:33:47 AM PLCBUS Device Device [138-M4] status set to [Off] May-20 11:33:47 AM PLCBUS Device Device [138-A4] status set to [Off] May-20 11:33:47 AM PLCBUS Device Device [138-M4] status set to [Off] May-20 11:33:47 AM PLCBUS Device Device [138-M3] status set to [Off] May-20 11:33:47 AM PLCBUS Device Device [138-A1] status set to [Off] May-20 11:33:47 AM PLCBUS Device Device [138-M4] status set to [Off] May-20 11:33:47 AM PLCBUS Device Device [138-M3] status set to [Off] May-20 11:33:47 AM PLCBUS Device Device [138-A2] status set to [Off] May-20 11:33:47 AM PLCBUS Debug SetIO[] name=[Scene : Test] address=[138-M4] type=[PlcBus Scene] controlValue=[0] May-20 11:33:47 AM Device Control Device: System zzINACTIVE Scene : Test to Off (0) by/from: CAPI Control Handler May-20 11:33:42 AM PLCBUS Debug Sent: (138) M4 SceneAddressSetup Data1:2 Data2:0 Tx:True AckReq:False Ack:False IDreq:False Id:False 3PhReq:True RiscOK:True PlcBusOK:True May-20 11:33:41 AM PLCBUS Debug Sending: (138) M4 SceneAddressSetup Data1:2 Data2:0 Tx:False AckReq:False Ack:False IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False May-20 11:33:41 AM PLCBUS Device Scene [138-M4] - Adding ON device=[138-A3] value=[101] May-20 11:33:41 AM PLCBUS Device Scene [138-M4] - Adding ON device=[138-A4] value=[101] May-20 11:33:41 AM PLCBUS Device Scene [138-M4] - Adding ON device=[138-A1] value=[101] May-20 11:33:41 AM PLCBUS Device Scene [138-M4] - Adding ON device=[138-A2] value=[101] May-20 11:33:40 AM PLCBUS Debug SetIO[] name=[Scene : Test] address=[138-M4] type=[PlcBus Scene] controlValue=[500] May-20 11:33:40 AM Device Control Device: System zzINACTIVE Scene : Test to Add currently 'On' devices as On (500) by/from: CAPI Control Handler
