Bob,
Yesterday I have finally installed the latest version of BLGData, did not test more after my last test with the trigger in Handlers. I noticed the trigger is now working correctly. So I am trying to make use of that, but I think the handler is not holding information on the calendar event triggering the handler?
Is this true and should I write a script to find the user/calendar event myself or is there a way to use the user and calendar object in the handler itself? I am a bit confused with the documentation as it is explaining the handler and then jumps to the objects. So I am hoping the objects are addressable inside the handler?
Wim
Wim
