Jayman, do you have Real Time Upload turned on? It's under Settings-Upload Server at the bottom of the page. Also, on the Trips page touch the most recent trip, scroll down to Upload Data Points. If it's successful, you should get a pop-up saying so.
Snevl Latitude Version 2 Discussion
Originally posted by stevea View PostUgh. Sorry about that. That sounds like it should be easy to track down. The XML file it tried to parse and process should be in the data\SnevlLatitude\BTraced directory. Can you zip that up and send it to me? (snevl at msn dot com) I promise to respect your privacy.
SteveBest,
Jakob Sand, I automate everything!
Originally posted by jbbtex View PostJayman, do you have Real Time Upload turned on? It's under Settings-Upload Server at the bottom of the page. Also, on the Trips page touch the most recent trip, scroll down to Upload Data Points. If it's successful, you should get a pop-up saying so.
Guest
Just downloaded this and installed setup btraced.
Every time btraced runs i get this this.
PHP Code:15/12/2012 07:42:30 ~!~Event~!~Event Trigger "SnevlLatitude Process BTraced"
15/12/2012 07:42:30 ~!~Event~!~Running script in background: SnevlLatitude.vb("BTMain","")
15/12/2012 07:42:30 ~!~Event~!~Deleting event after run: "SnevlLatitude SnevlLatitude Process BTraced"
15/12/2012 07:42:30 ~!~SnevlLatitude~!~Looks like DB version 2, requires upgrade to version 4
15/12/2012 07:42:30 ~!~SnevlLatitude~!~Adding 'DevMap2' column to Badges table
15/12/2012 07:42:30 ~!~Warning~!~SnevlLatitdue - DevMap2 field is already in Badges table.
15/12/2012 07:42:30 ~!~SnevlLatitude~!~BTraced table found - not added
15/12/2012 07:42:30 ~!~SnevlLatitude~!~Adding UseLatitude checkbox to BADGES table
15/12/2012 07:42:30 ~!~Error~!~SnevlLatitude: Error while trying to upgrade DB to version 4: Field 'UseLatitude' already exists in table 'BADGES'.
15/12/2012 07:42:30 ~!~Error~!~SnevlLatitude: Failure parsing new BTraced XML
15/12/2012 07:42:30 ~!~Error~!~System.Runtime.InteropServices.COMException (0x800A0E78): Operation is not allowed when the object is closed. at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack) at scriptcode8.scriptcode8.init_btraced(BadgeClass& b, String devID) at scriptcode8.scriptcode8.BTMain(String dummy)
15/12/2012 07:42:30 ~!~Error~!~Scripting runtime error: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Runtime.InteropServices.COMException (0x800A0E78): Operation is not allowed when the object is closed. at Microsoft.VisualBasic.CompilerServices.LateBinding.InternalLateCall(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack, Boolean IgnoreReturn) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateCall(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, Boolean IgnoreReturn) at scriptcode8.scriptcode8.BTMain(String dummy) --- End of inner exception stack trace --- at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters) at Scheduler.VsaScriptHost.Invoke(String ModuleName, String MethodName, Object[] Arguments)
Guest
Got it working
Downloaded v1.9 copied the database over to homeseer ran the script and the database updated.
Originally posted by jayman13 View PostTried all that and I do have real time upload turned on. Interestingly, when I hit upload data points I get a pop saying there are no new points to upload...Does it matter that this btraced app is under one itunes account. I mean, I have it on my phone but my wife and I share itunes so how does btraced get a "btraced id". Is it from the actual phone or is it one itunes account?
iphone 5 as far as I know should work ok. I understand that Snevl Lat is using the iphone's ID not your Apple account. During BETA testing there was a problem when first installing BTraced 1.1 in that if 1.0 was not installed BTraced would not connect to the server, however, the BTraced guy's said this was fixed for download from the Apple store so I presume the problem was because I was installing direct from a website rather than the store.sigpic
Btraced 1.1 is available in the appstore
Good news:
Btraced version 1.1 Is available in The appstore for update or download
If you really like it please rate it for us
new features:
- Added compatibility for iOS 6 and the new iPhone 5 screen
- Upload protocol now supports Basic Auth making it for example compatible Homeseer (Snevl Latitude script is supporting btraced)
- functions for sharing your trips on Facebook and Twitter, see protocol document (try it out on http://www.btraced.com)
- Added timezone when uploading the trip to the server
- Fixed compatibility with special characters in the trip name
- Fixed some timing display issues
- Fixed crash when all the trips were deleted
- Fixed "Add point on turn" feature on 359 degrees heading
- Fixed live upload with "Continues" always on 1. Now it will report 0 when the trip is stop in real time
- Some other minor bug fixes
- UI Improvements
you can find the new protocol document here
http://forum.btraced.com/viewtopic.php?f=3&t=414
Upload 1 point to btraced.com and your position will be ananymous on btracedworld
http://www.btraced.com/btracedworld.asp
Many regards
Pieter
Originally posted by Gogs View PostWhen you say there are no points to upload I presume if you look at the map in BTraced it has actually plotted a track, even only one point, the otherthing is if BTraced thinks it has uploaded the track you have to "Reset Ulpoad Status" for it to try again.
Originally posted by 8r1an View PostJust downloaded this and installed setup btraced.
I need to go look at this. I think I missed something in how I check to see if you need to upgrade. I see from a later message that you got it to work by installing v1.9 and then upgrading to v2. I assume the failed attempt was simply a clean install of v2?
Steve
should work. I use iphone5 myself.
Jayman,
I just tried to install on my wife's iPhone 4 and it's not working for me either. On the Current Trip screen it shows tracking but the Live status indicates that nothing has uploaded. And if you touch a saved trip, then View Data Points, the list is empty.
Is this what your getting?
I've sent all this in an email to the BTraced developers.
Boyd
