Go Back   HomeSeer Message Board > Telephone,Text and Email Plug-ins > Telephone,Text and Email Integration Discussion
Old September 27th, 2014, 04:00 PM
jrhubott jrhubott is online now
Find my iPhone plugin for HS3
Plugin is now in the updater. I will be adding a configuration interface but for now please follow the following instructions.
Run it once to create the HSPI_RSFindMyDevice.xml config file.
Edit the file and set the following values: This is your itunes account
<Username></Username>
<Password></Password>
Set the API key if you want maps and reverse geolocation - you can get to the API from this link: https://console.developers.google.com
<GoogleApiKey></GoogleApiKey>
The API must be enabled for the following services:
Geocoding API
Static Maps API
Restart the plugin. More updates to following including GeoFencing events and actions
New Version Release Notes:
V1.0.1.1 - 11/30/2014
Updated to work with new Apple authentication scheme
V1.0.0.8
Added a refresh button for each account. It can also be used in events.
1.0.0.6-
Added
<DownloadGoogleMaps>true</DownloadGoogleMaps>
1.0.0.5-
Support for multiple accounts - you will need to add your username / password again to the xml file as the format has changed to support multiple accounts
Support for update rate per account
1.0.0.4-
Added support for RadiusGeoFences. You can add as many as you need - do not remove the Value 0 RadiusGeoFence- you can edit the name though if you want.
The Geofence device can be used in events.
All geo coordinates are logged to the HSPI_RSFindMyDevice.csv file in the Log directory. This file is updated every minute.
<RadiusGeoFences>
    <RadiusGeoFence>
      <Name>None</Name>
      <Value>0</Value>
      <Latitude>0</Latitude>
      <Longitude>0</Longitude>
      <RadiusInMiles>0</RadiusInMiles>
    </RadiusGeoFence>
</RadiusGeoFences>
Plugin must be stopped when editing the xml file.
HS3Pro on ESXi6 Windows 10 Server VM
Z-Net running VirtualHere to enable Insteon PLM
65 Insteon Zones | 15 ZWave (2 Door Locks) | DCS 1832 Alarm Panel | Plex HTPC | 6 IP CAMS | 2 Nest Thermostats | 6 Sonos | 11 Squeezeboxs | Blink EVSE | Pentair EasyTouch Pool Control | Denon AVR-991
My plugins: Nest Thermostat | Blink EVSE(Nissan Leaf eCar) | Pentair Pool & Spa
Old September 27th, 2014, 04:38 PM
bernieb bernieb is offline
Can you give us some ideas of what the possibilities are with this plugin.
Old September 27th, 2014, 06:21 PM
It creates devices for all of your phones for geolocation. I will post a screenshot.
Sent from my iPad using Tapatalk HD
Old September 27th, 2014, 09:28 PM
Features:
-Device groups for each registered FindMyIPhone device
-Longitude and Latitude
-Battery level
-Geo fences by name
-Google map location icons and pop-ups
Future:
-Location based events by enter/leave geofence area
-Battery level events
-Remote locate devices
-Remote sounds and messages
-Remote wipe(maybe)
-Database logging of geolocation
Old September 27th, 2014, 09:34 PM
Digger1 Digger1 is offline
Lots of potential. I want to give it a try when I start over with HS3 next week.
Old September 27th, 2014, 09:52 PM
jayman13 jayman13 is offline
How often does it poll the location? Just wondering about how to the minute geofencing would be. Thanks.
Old September 28th, 2014, 02:27 AM
Rien du Pre's Avatar
Rien du Pre Rien du Pre is offline
This is cool, was waiting for this a long time ---
Will install it today...
Rien du Pre
The Netherlands
Using:
Homeseer PRO 3.0.0.368 on MacOS - Running a Mac Mini
Plugin's:
RFXCOM, Caddx, HarmonyHub, BLShutdown, BLLogMonitor, BLRadar, BLBackup, FritzBox, Log2Text, BLLAN, PHLocation, Z-Wave
Link to the forum of my Plug-ins http://board.homeseer.com/forumdisplay.php?f=1216
Old September 28th, 2014, 08:25 AM
I got it installed and working. As it stands now though I can't really do anything with it. Looking forward to updates. Lots of potential I think
Old September 28th, 2014, 11:00 AM
Any suggestions for future features?
Old September 28th, 2014, 11:32 AM
Not sure of the possible capabilities but some ideas i was thinking about which may already be possible......
If your kids iphone does not arrive at school or home by x time send a text/email
If its between midnight and 6 am and battery level drops below 20% run an event to alert you to charge.
If you arrive at home and battery is below x percent run an event to remind you to charge.
If you arrive at home and your alarm system had tripped set off phone alarm as a warning
I would like if i am arriving at home start a timer fir blue iris plug in not to record and email for 10 minutes. Hate tons of emails as i unload the car etc.
I think others will have much better ideas.
Old September 28th, 2014, 01:31 PM
Phaeton Phaeton is offline
Where can I get an API key? when looking here: https://developers.google.com/maps/signup?hl=nl they say a key is not available/necessarily.
the status of my root device keeps saying : Initializing
This looks like a really nice plugin with a lot of potential!
Old September 28th, 2014, 02:33 PM
I found it. Only reverse geocoding doesn't work. Which service should I enable to get this to work?
Old September 28th, 2014, 03:02 PM
See my updated first post for the required services. I also will be releasing a new version today that has Radius based Geofences that can be triggered on.
Old September 28th, 2014, 03:04 PM
It updates every minute. I used it today to record a 20 mile bike ride and then plot it out. It was pretty accurate.
Old September 28th, 2014, 03:15 PM
Your link in the openingspost gives an errorpage. Im nog authorized tot view the page.
Verstuurd vanaf mijn Nexus 5 met Tapatalk
Old September 28th, 2014, 03:27 PM
rprade's Avatar
rprade rprade is offline
The link in the first post is to a developer's page.
Randy Prade
Aurora, CO
Prades.net
Old September 28th, 2014, 05:53 PM
New version posted with support for GeoFences.
Old September 28th, 2014, 06:17 PM
jbbtex's Avatar
jbbtex jbbtex is offline
Will it support multiple accounts? In other words, will I be able to use this for each family member's iDevice?
Brady
Old September 28th, 2014, 06:47 PM
I will add this in the future. Right now it just supports one account. That account can have unlimited devices on it though.
Jason
Old September 28th, 2014, 08:23 PM
This may be a stupid question. But this plugin wears all your batteries down quicker right? In other words, Apple doesn't poll for devices location unless queried, right?
installed new dedigner, can't find Iphone project? DMcKnight Designer 1 April 11th, 2014 11:47 PM
How do I find the NetCam plugin for HS2? buvens HomeSeer NetCam Plug-in 3 March 21st, 2014 09:51 PM
Where would I find plugin? buvens BLShutdown 2 January 13th, 2014 09:13 AM
where do I find the the iphone sample.xml and other deplyed projects? Jakob.Sand Clients - Apple iPhone/iPod/iPad 13 October 19th, 2009 08:58 AM
Can't find Unlimited Plugin V1 neiltimms HSTouch™ 2 April 1st, 2009 10:14 PM
