Can I get some more details around triggers with PHLocation?
In the manual it has this:
Will this only work with a Tracking/Position user or with a GeoFence user?
Will this fire off anytime the Location changes? Can this be enhanced to when location changes and becomes?
I'm trying to see if I can use this for detecting "Home" status for opening the Garage Door for the family. Yes, one user I can do that with IFTTT, but with multiple users and them not technical it becomes problematic with trying to get them to setup accounts etc etc. Easier if I just install EgiGeoZone on their phones and pull a configuration. (wonder if I can push it?? check that later).
Anyways, how can PHLocation be used for triggering Home/Away type events and not fire on every location change?
The "New Location" trigger type will fire whenever user type device is updated with a new location. Select New Location as the trigger type and select a user type device on which to trigger.
