The Fibaro Dimmer 2 looks like an interesting product http://www.fibaro.com/manuals/en/FGD...-v1.01-3.2.pdf
Z-Wave+, power monitoring and configurable for leading or trailing edge (even in 2-wire mode) so should be more compatible with LED's.
I've often wondered why they couldn't make a Z-Wave trailing edge dimmer module to work in 2-wire mode when such devices (on other technologies) have existed for a number of years.
I have several Home Easy HE108 dimmers still in use here. They are trailing edge, 2-wire, RF controllable (with RFXCOM) and work perfectly with most dimmable LED and CFL lamps. The only negative is that they don't have 2-way comms which isn't ideal for a HA situation.
Paul..
Paul..
