Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > MyHS Remote Access Service
MyHS Remote Access Service Discussions regarding myHomeSeer Remote Access Service
Old September 27th, 2016, 01:48 PM
integlikewhoa integlikewhoa is offline
How to use Http Get with my.HS
I have multipule HS3 servers in multiple locations and I currently port forward and send http command to flip virtual switches on/off via tasker. I'm trying to take the next step and close up my ports. How would I send an http command via my.hs to flip a virtual (set status) to on or off?
Old September 27th, 2016, 01:55 PM
mrhappy mrhappy is offline
If you have the JSON interface enabled you can connect through connected.homeseer.com with your login details from MyHS - example here https://homeseer.com/support/homeseer..._with_json.htm
Old September 27th, 2016, 03:38 PM
Why thank you that did just what I was looking for.
https://connected.homeseer.com/JSON?...ef=384&value=1
I'm really new to all this, but I'm going to assume that my next security step will be to remove the user and password from the http request? But this has to be alot more secure then just opening up homeseer ports as I was doing before.
Old December 26th, 2017, 01:25 AM
XboxMeister XboxMeister is offline
Resurrecting this thread as I was just trying to determine if specifying a specific host was possible via MyHS with a JSON command. I've got a couple of HS instances in different places (and may add more) and signed up for MyHS Premium but not sure how to direct a command to a particular HS server (other than setting up separate users which isn't preferred).
Anyone figure this out?
Old December 26th, 2017, 10:44 AM
Yes, setup different users is the anwser. I use my main username for everything still but i created a user with "myusername.home" and another one something like "myusername.2ndhouse" or I use city names, but I use these just for this case only.
Old December 26th, 2017, 03:23 PM
Cool, thanks. I set it up in MyHS and seems to work well. Many thanks!
Http trigger heimdm HSTouch™ 1 January 7th, 2016 11:26 AM
Http requests Dpaget21 Audio / Video and Infra-red (IR) Discussion 2 December 7th, 2012 06:29 AM
http 404 not found MUEcorp HS2 / HSPRO 4 April 7th, 2012 06:40 PM
HTTP Post & HS mrhappy HS2 / HSPRO 2 April 2nd, 2010 04:14 PM
