Multiple questions--sorry in advance for the ignorance, I'm new to this and am trying to understand potential scale and cost for a system I haven't started building yet. SO:
thanks...it looks promising but I'm sure I'm missing some aspects of the design problem just by reading web pages.
- Does the Ultra plugin separately log all the sensors that feed into the Gen2 EDS MN-ENV-H-THX? If so, does that sensor loaded with 3 probes yield a database with temp/rh for the base unit and temps for each probe, i.e. four temp data points and one RH data point at each time step?
- Other than Homeseer integration, does the Ultra plugin offer any advantages over whatever logging is provided by EDS? For example, does the EDS-only system require buying another device to do logging? better charting with one or the other?
- With just one MN-ENV-H-THX sensor device deployed, would I also need the EDS MN-CTRL-H controller to interface the sensor with the Ultra plugin?
- Assuming I'd need the EDS MN-CTRL-H controller plus the THX sensor plus the plugin to get the system started, could I then expand it either with additional Gen1 wireless sensors or with 1-wire components (say using OW-Server) and still feed the same data log?
