Hi Don
I've installed 5 lutron roller blinds and have them enrolled in the Caseta Pro bridge, Also installed the Pico remote to the bridge.
The plugin installed and I created the 5 blinds devices. In my homeseer log I am getting the following error
Jan-12 12:33:15 PM LutronCaseta try connecting to the SmartBridgeS1 telnet IP address 10.31.xxx.11Port: 23
Jan-12 12:33:14 PM LutronCaseta ERROR Unable connect to the SmartBridgeS1 telnet check the IP address. Error: 10.31.xxx.11:23....A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 10.31.xxx.11:23.
My system is a Homeseer S6 Pro and is on the same network as the Bridge.
Am I missing something in the setup or is there an issue with the port23 on the network??
